Any difference between lingenfelter or regular Bando belt 11PK2095?
I’ve searched and tried to figure it out exactly but wanna check with you guys. Given my setup I need to run the 76mm idler plus the lingenfelter 11PK2095 belt. So its 80$ from them and they don’t have it in stock or you can get the bando same part number for 45 bucks. Is there any difference with the actual belts for quality etc. Next is this Bando the exact same specs as the lingenfelter? I’ll post a link to the Bando for comparison. Thanks in advance https://kpaulindustrial.com/bando-11...SABEgImf_D_BwE
Bump again. Is anyone running the regular bando branded belt? It looks like lingenfelter belt might be back ordered until past my tune date so I gotta figure something out. Thanks
Bando belts work good
