Official Cam spec thread
Folks, this information is sought by me because I run them through an engine modeling software that can run ANY cam, heads, intake, header, blower, etc. specs and hypothesize HP, TQ, power/tq under the curves etc. I'm trying to gain cam specs to see which ones work (make ideal power/tq) and which ones don't. Yes there are cams out there...but I'm trying to create a repository of GOOD cams that MAKE POWER for the good of the community. This wont be an overnight thread. This will be a long, drawn out, couple of months type of thread.
When I'm towards the end of the thread, I'd like the community to know what cams work BEST for stock LS7s, mildly modified, or your specific combo. The sky really is the limit. Those members who've already picked a combo may not benefit much, if they're not willing to change combos. But Let others see the results of your decisions. That's ALL I'm shooting for.
A cam thats a dog in one car may not be a dog in another due to the differences in the setup; a .650 VL cam in a motor with heads that stall at .630 will perform poorly, the same cam in a car where the heads stall at .700 will perform entirely different. My cam may run like crap on stock LS7 heads yet in my car, it carries 500+tq out well past 6000rpm
This idea would be helpful if you could populate a few more cells on the spreadsheet....
I'd like to see lobe lift numbers: .004/.020/.050/.100/.200/.300 - to peak lobe lift and back down the other side. Gives a much better picture of the lobe profile. Also keep in mind that most modern lobe profiles are NOT symmetrical, and lobe centerline is rarely halfway between open/close points.
The following 2 users liked this post by Michael_D:
Millenium Z06 (04-23-2018),
Pb82 Ronin (04-23-2018)
Then you're still missing the point that the less "capable" people are telling you.
The software uses a sliding scale of "lobe acceleration" from 1-9. So yes, those numbers would be helpful to determine the lobe acceleration specs, but they aren't able to be directly input as listed. But after a few cams rates as you described came out, I could begin to see which lobes/cams were more aggressive vs. less aggressive. So I agree, those numbers would be helpful...but it's hard enough getting people to list more than just lift/duration numbers.
And yah, I know all about lack of data from cam grinders. They hold it pretty tight to the chest and even if you buy a cam from them, the card doesn't have all the pertinent information. With my degree wheel and a dial indicator, I record everything. That won't help you though, as I can't remember the last time I bought an off-the-shelf camshaft.
Who was the famous engine builder that said something like "find what works, then then build the theory around it" or something like that?
Just like how you said the CID heads are not that good, based off some minimal data, yet they cranked out 1100+hp N/A. Spend some time talking to the comp guys, or cam people like Billy@Comp and it is a whole new world that is way beyond most people here. Much easier to tell them what you want, and let them come back with the proper setup, than trying to model stuff.
What software are you playing with? I've messed around with a few over the years. They can be a fun tool, but I don't put that much faith into them. Pipemax seems to be pretty helpful though....
Food for thought...the software I'm using is the same as what COMP uses.
#33
I don't remember seeing that quote, but it sounds like something Smokey would have said.
#34
I looked at that software. It looks eleborate. I've used Engine Analyzer Pro a bit, but not the DynoSim. They look comparable.
#35
Yah was talking to op.
I guess my point is let comp or some one that does this daily do the hard stuff. The comp people have been amazing.
#37
I'll play along,
BTR Stage 2
Hyd. Lifters
Duration @ .006 286 intake 299 exhaust
Timing @.050 Int open 4*BTDC close 46*ABDC
Exh open 62*BBDC close 4*ATDC
ILC 111*
Duration @ .050 231 Int 246 Exh
Lobe Separation 115*
If interested other mods are Ported LS7 heads, 12:1 comp, ported stock intake. Made 565RWHP, 522RWTQ
BTR Stage 2
Hyd. Lifters
ILC 111*
#38
Pat G custom cam.
TSP cut this cam and lift is .635 on intake and exhaust. Lobes are TSP353 according to my build sheet.
Cam Valve Events
.050"
Intake Duration
236
Intake Valve opens
7
BTDC (- indicates ATDC)
Exhaust Duration
250
Intake Valve closes
49
ABDC
Lobe Seperation Angle
115
Exhaust Valve Opens
64
BBDC
Intake Centerline
111
Exhaust Valve Closes
6
ATDC (- indicates BTDC)
Exhaust Centerline
119
Overlap
13
degrees
Cam Valve Events
.050"
Intake Duration
236
Intake Valve opens
7
Exhaust Duration
250
Intake Valve closes
49
ABDC
115
Exhaust Valve Opens
64
BBDC
Intake Centerline
111
6
Exhaust Centerline
119
Overlap
13
degrees
#39
#40
Pat G custom cam.
Cam Valve Events
.050"
Intake Duration
236
Intake Valve opens
7
Exhaust Duration
250
Intake Valve closes
49
ABDC
115
Exhaust Valve Opens
64
BBDC
Intake Centerline
111
6
Exhaust Centerline
119
Overlap
13
degrees
Cam Valve Events
.050"
Intake Duration
236
Intake Valve opens
7
Exhaust Duration
250
Intake Valve closes
49
ABDC
115
Exhaust Valve Opens
64
BBDC
Intake Centerline
111
6
Exhaust Centerline
119
Overlap
13
degrees
