[ZR1] How to monitor IAT2? What are you guys doing?
im doing a bunch of mods including changing the upper pulley and I would like to start monitoring intake temps after the blower. For those that are doing this how are you guys achieving this. Can you run something off the obd2 and add a gauge to display or tap the sensor and add a gauge etc etc. I’m not too worried about logging the data I just want to be able to see what data and that way I know if I need more cooling mods and if the ones I’m doing are working. Thanks
You can monitor live with use of dashlogic plugged into obd2. Otherwise you can log it or monitor via laptop with HP Tuners. Most of us use dashlogic to monitor it live through the dash (both heads up display and the dic)
As others have stated, install a wideband, tie it into a dashlogic (or physical gauge if you prefer) and call it a day. I did a PLX to dashlogic install and it was super easy and can be removed fairly quickly if needed.
