Oil Leak
Oil Leak
09Z 11k on the clock. So this oil leak seems to be centered around the drivers side very last oil pan bolt. The leak goes down the filter and drips from the bottom of the filter. I have headers, checked the oil cooler lines and they are good. Pan gasket?
thanks man, I just blasted everything with brake cleaner, im going to check over the next few days. Is the oil pressure sensor a common "leak" item? I dont remember seeing too many threads on it.
How long has your car been sitting this past winter? Do you live in a colder climate?
I had an oil leak in the same location and turned out to be the oil filter rubber o-ring changing shape/size/deforming while sitting in my garage for ~ 6 months during the cold WI winter.
It could also be the oil pan gasket deforming from sitting so long (from my research). After a few heat cycles, the oil pan gasket and oil filter o-ring should seal up quite well.
1.) Change the oil and wipe all of that dripping oil as best as you can.
2.) Drive it for a few days then get under the car and see if you notice any more dripping oil.
Hmmm. Change the oil again and wipe everything down nicely. Add some of this to your oil (buy the kit for $46.21 a little further down the page). Drive it for a day or two, get under the car and hit it with the uv flashlight. Should help you better trace the stream of oil. Hopefully it's not your rear main seal.
are these what you are talking about? where the arrows are pointing? If so, they are dry, I stuck a q tip in the valley where the bolts are and it came up dry.
hard to tell, I first noticed the leak in November while changing the oil. So I wiped down what I could (without brake cleaner like an idiot). So the current pics are a new filter and the car was only driven down the street and idling in my driveway. If the filter took a ****, would the leak be so wide spread? Its everywhere.
Question for you, did you mess around with the oil cooler plate you see in there in the picture? That could be another culprit even if you didn't.
Just asking because I ran across this thread started by you:
https://www.corvetteforum.com/forums...block-off.html
Yes, those are the ones. But there is another one not visible in your picture just behind the oil cooler plate. There are 5 on each side.
