Under hood fuse box
Under hood fuse box
Underhood fuse box the fuel pump relay keeps blowing.i pulled the block and it is burned on the bottom male ends of the top block and the female ends that the male screw into underneath on the bottom like a sandwich.
Could this be a fuel pump shorting? If so where do I find a complete fuse block top and bottom and a new fuel pump. I am by the way running a bap on it as well.
The car is a 2008 corvette z06 with 30000 miles on it.
Please HELP!!!
Please HELP!!!
Follow the grey wire, there is another connector further back from the fuse box as well. Make sure the connection is clean.
As for the relay - order up a new one from the dealer they stock them or any micro 280.
