[Z06] Which MGW shifter to I need for my c6 ZO6? 2 different versions
Went to go order a mgw shifter and seen there was two different version. One says flat stick short throw and other short throw shifter. What is the difference between the 2? My question is which one do I need to go with? It’s going on a 08 C6 ZO6 with a N/A motor. Thank you for your help
Oldslick09 (01-05-2022)
1/4 mile/AutoX
the flat stick has a little curve to it and it mounts straight up from the box the standard stick is offset to the back and is straight up no curve, I love the flat stick seems to have a better position feel for me !!! (had the standard to start with)
1/4 mile/AutoX
1/4 mile/AutoX
I just ordered the standard one so I could use the stock shift **** . I like the way the stock shift **** fits in my hand. I can’t wait to install it. Thanks you guys for all the feedback
FYI, I emailed MGW and here is what I said and got from them:
I just bought your short shifter for my C6 Z06 today, but I have a question about the specific differences between the short throw shifter with the round shaft, and the short throw shifter called the "flat stick"
The flat stick obviously comes in colors, and it's aluminum, and it's slightly angled - but are there any other differences? Is the throw shorter or longer?
Could you send a picture of a side-by-side comparison if there are other differences? Since I bought the standard short throw, could I upgrade to the flat stick later, or are they too different to do that?
other than cosmetics there is no difference they function the exact same and yes you can buy the parts to make it a flat stick at a later time if you want.
julie
MGW Shifters Support
support@mgwshifters.com
julie
julie
julie
nuke61 (05-15-2018)
Received 1,679 Likes
This is the one I got... Will be here tomorrow...
This one here is the ****. I would also get the Race **** to go with it.
This is the one I have.
https://www.mgwshifters.com/shifters/corvettes/88
Mine should be here in a couple of days!!!!
