2008 Z06 LPE660 to Iron Dart LS Next Pro 427 / F1X - Build Thread
Dart LS Next Pro 427 F1X A2W - Build Thread
So, I figured I would go ahead and start a build thread as some big things are in the works for the car.
Currently the car has 11k miles on the clock, the motor is still a stock bottom end, stock head casting LS7 with the LPE660 package with a few other bits.
Here is what we are working with currently and I will provide what we have for the build.
Currently:
Gary Ochs - Ochs Performance - Plano, TX
Older Photo's on 20's
Older photo before the MGW
Sitting on CF5's before the wrap
After the wrap
After the wrap
After the wrap
After the wrap
Currently:
- LPE660 LS7 11.5:1 H/C/I
- GT-21 Cam
- Katech Oil Pump
- Fast 102 intake
- LPE ported TB
- LPE MAF
- LPE Cold Air
- Fore Innovations dual wide system
- 2x Walbro 267's
- Fore Innovations FP Regulator
- Fore Innovations Billet Rails
- Injector Dynamics F750 Fuel Filter
- Injector Dynamics 1050x
- DSX Flex Fuel Kit
- ARH 1-7/8 Long Tubes
- Corsa Sport Exhaust
- LPE LS9 Twin Disc Clutch for LS7
- RPM Stage III diff w/ 3.90's
- MGW upper and lower with race ****
- ZR1 roof
- APR Chin and Skirts
- Supervettes 1.5" Widebody Rear Quarters
- Supervettes GT6X Carbon Spoiler
- Supervettes / APR Rear Carbon Diffuser
- APR Carbon Cluster Surround
- LPE White Faced Gauges
- Corbeau Evolution X Seats
- Brey Krause Harness Bar
- LPE white faced gauges
- Forgestar F14 20x10 F 20x12 R - Bronze Burst
- Forgestar CF5 18x10.5 F 18x12 R Bronze Burst
- Carbon Headlights
- Caravaggio D-Bottom Steering Wheel
- Pfadt Featherlight Coilovers
- Pfadt Sways
- 3M - Satin Flip Ghost Pearl Wrap - Stormtrooper - Wrap Dynamics
- DMS - Dedicated Motorsports Tuned on a Mainline Hub Dyno ~600RWHP on E
- Dart Iron LS Next Pro 1/2 Stud
- Callies Magnum CCW 4.000
- Callies Ultra Enforcer 6.125
- BTR Custom Diamond Pistons / Coated 12:1 (High Compression for boost I know but E and Race Gas Only)
- Johnson STSLR Hydraulic Roller Lifter
- Cam ground by Cam Motion - 248/262 .652/.635 116 LSA
- Athena Head Gaskets
- LME Brodix BR7's - Titanium Intake Valves, retainers, locks etc. Stainless Exhaust Valves
- Springs - BTR
- Crower Shaft Mount Rockers
- Shauns Custom Billet LS7 Intake and Valve Covers
- ARH 2-1/8 Longtubes
- Innovators West Dampener
- Dallas Performance 10 Rib setup
- F1X Procharger
- Dedicated Motorsports A2W
- Procharger Race Bypass Valve
- ID 1700's
- DMS Catch Can
- Newer C6 ECM Upgrade - Mine is not passing self test sometimes...
- RPM Level 5 TR6060
- RPM Level 4 3.42 diff
- DSS CF prop-shaft
- DSS Level 5 300M axels and hubs
- RPS BC3 Clutch
- Tilton Duty Master / Slave Cylinder
- Fore Triple TI 274's
- Dewitts radiator and dual fan pack - cut down
- Improved Racing oil cooler EC6-600
- Carlyle 15" Conversion
- Weld Aluma Star Fronts
- Weld RTS S71 Single Beadlock Rears - still working on the fitment for the widebody
After the wrap
After the wrap
After the wrap
After the wrap
droptopsnake01 (07-29-2019)
Thank you! I just got her back last night from the wrap shop.
As far as HP I'd say 1300ish on the Mainline which is a heart breaker, at least with the F1X it should be in range. The goal eventually will be to go to a bigger blower or turbo the car, the motor has a bit of headroom before we have to go a bit bigger. Chasing that MPH number in the 1/2 LOL...
It'll take a bit of seat time to get to a point where we have it all dialed in and get it from A to B. On the street it will be a nightmare but not it's primary use.
On the gears, are you wanting to swap diffs? I was thinking you had the same level III that I had with 3.4X gears? I need to get some input on how high to gear this thing for the 1/2 at the power level it will be at on a radial. At least the power will be linear on the Procharger...
Hey brother, thank you! We absolutely need to sync up before everything gets put together, I have two sets of drag radials to use up before I go 15". Let me know when you want to run them, it will be fun. I have a feeling I am going to get skull dragged but it will be fun nonetheless.
Think I saw your car at The League Saturday night; said to my wife "that Vette has a cam in it." Haha. Highly recommend you get a CamMotion cam with it's better lobes, those GT-21's will wreak havoc on your valvetrain. Get good guides and choose your valves wisely. Johnson lifters are excellent. I really like the way your car looked before the wrap.
GT-21: 243/259 duration @ .050 lift -.691/.702 lift with 1.8 rocker 112 CL 🤔
Yup, Yup. Just saw this...
The Corbeau's are quite comfortable, look good and hold me in pretty well. They are a fixed back seat for the C6 due to width constraints and have an air lumbar support, in my opinion they are one of the best bets for the price if you are looking for an aftermarket racing seat and or weight savings. 👍🏼
Nice, you’re build is close to what I have in mind except I am going turbo. LSNext with the same internals and BR7’s haha.
Billet IM and valve covers are sharp.
