Z06 question about front wheel splash guards
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Hi guys, I'm looking to retrofit both the front facing (front of wheel) and front behind wheel splash guards to my wide body C5. Can someone tell me if the these pieces are part of the fender liner or separate pieces as I am getting conflicting information.
You might get a better response if you post this in the C5 forum. Unless you are talking about using C6 parts on a C5. The splash guard in front of the wheel is part of the the fender liner on the C6. There really aren't any splash guards behind the front wheel, at least not stock.
STALION (06-19-2018)
From some pics I've seen, there is a small splash guard behind the front wheel as well. Can you confirm if this is also part of the fender liner, as I can't seem to find any part numbers associated with it.
those splash guards on the rear of the front wheel wells are after market, made by apsis, and they do work.
Thanks for your input. You helped answer one of my questions, that the front facing splash guard is attached to the fender liner. My plan is to modify this piece for a C5.
