C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Mild to Wild
Old 07-02-2018, 09:24 AM
C6Z06Silverbullet
C6Z06Silverbullet's Avatar
Default Mild to Wild
Does anyone make a mild to wild switch to fit in the ashtray?
Old 07-02-2018, 09:45 AM
99Hawk262
99Hawk262's Avatar
If you search mild to wild DIY, there's a writeup that I used for my last Z that was super simple, and cost less than $5 if I remember...it's a fuse and a switch of your choice. I placed a round switch where the cigarette lighter was since I'd never used it or planned to use it. I'll see if I can find it.
C6Z06Silverbullet (07-02-2018)
Old 07-02-2018, 09:59 AM
C6Z06Silverbullet
If you leave the switch in the off position will it still work like stock?
Old 07-02-2018, 10:08 AM
427C62013A
427C62013A's Avatar
Yes. Off is like stock. On is loud all the time.
Old 07-02-2018, 10:13 AM
C6Z06Silverbullet
So the flaps would still open up after 3500 rpm like it does from the factory correct?
Old 07-02-2018, 10:24 AM
427C62013A
427C62013A's Avatar
Yes if your foot is in it. If you do part throttle they stay closed.
Old 07-02-2018, 11:10 AM
LMB-Z
LMB-Z's Avatar
Do a search on ebay for mild 2 wild...corvettecentral.com has one that is controlled by a switch. You can put it on your dead mans pedal (farthest to left). Out of the way, easy to use, takes 10 minutes to put in. No fob. Take the dead man pedal off, drill a small hole through it (its plastic), install the switch, run the wire through the console and into the fuse block on the passenger side, done. I guess if you wanted, you could put the switch in the ashtray, but the foot control is much easier and out of the way. Simply move your foot and push.
Old 07-02-2018, 11:13 AM
C6Z06Silverbullet
Yes I was looking at this option also. Thanks
Old 07-03-2018, 05:40 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
I have the "old school" M2W, which is the dead pedal switch. Works great for me.
Old 07-03-2018, 11:44 PM
Josh B.
Josh B.'s Avatar
Same here, I love my dead pedal switch. Cheaper than the console switches or the shift ****. Stone simple.
Old 07-04-2018, 08:34 AM
C6Z06Silverbullet
Yeah I think that's what I'm gonna end up doing. I just installed BBE Gen 3 last night. Oh my God why did I wait so long! It sounds incredible. Haven't taken to the road yet but just the difference at idle us unbelievable. Happy 4th!
Old 07-05-2018, 10:04 AM
itomh
itomh's Avatar
Added my own switch right of the ashtray and modified the cigarette lighter housing for under $25. Since I run in the open position 99% of the time, I opted to have LED light on when in the closed position. looks pretty clean IMO.
Old 07-05-2018, 10:11 AM
C6Z06Silverbullet
Looks good!
itomh (07-05-2018)
Old 07-20-2018, 04:35 PM
C6Z06Silverbullet
I went with the deadman switch. Installed it today very easy set up done in 15 minutes.
To Mild to Wild
Quick Reply: Mild to Wild
