C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
Old 09-11-2018, 04:28 PM
  #221
Millenium Z06
Moderator
Millenium Z06's Avatar
Originally Posted by Josh B.
I hope so I hope to make the Hi Ram Mafia proud.
Hi-Ram or GTFO
Whistling as I walk by....@jayyyw too
The following 2 users liked this post by Millenium Z06:
jayyyw (09-11-2018), Josh B. (09-11-2018)
Old 09-11-2018, 05:17 PM
  #222
jayyyw
jayyyw's Avatar
Originally Posted by Millenium Z06
Hi-Ram or GTFO
The following 4 users liked this post by jayyyw:
DualQuadDave (08-02-2023), HC Mechanic (09-04-2022), Josh B. (09-11-2018), Millenium Z06 (09-11-2018)
Old 09-12-2018, 01:14 AM
  #223
Josh B.
Josh B.'s Avatar
Considering cutting my LG carbon fiber intake to make it work with the Hi Ram. Cut along the red line. Cut out the MAF flange and relocate it to the other side of the red line.
6” to 5” silicone reducer sleeve to a short 5” 22* steel bend, then a 5” to 4.5” sleeve into the 108 TB. Just need to find a quality epoxy to glue the MAF flange in place. Carbon fiber to carbon fiber.
Old 09-12-2018, 03:01 AM
  #224
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
I vote No...that’s like defacing the Mona Lisa. I still say you try to fab a new lid, or use your current one to create a mold and make a new lid in dimensions you want...out of fiberglass or something maybe. Yes, I know...easier said than done.
Old 09-12-2018, 06:05 AM
  #225
MickVette
MickVette's Avatar
St. Jude Donor '13
If you can get that to work it sure would funnel a TON of air into the intake!!!!!
Old 09-12-2018, 07:34 AM
  #226
double06
double06's Avatar
I think I would try using a Halltech unit or something like that that you can wiggle around as you like. Another idea might be to shim the mounting point on the plastic piece up front with some stirofoam/rubber kind of stuff. Looks right now it is 45 degree tile maybe tilt it to 55 degrees or whatever will work not sure how much higher intake is in front from your MSD.
Old 09-12-2018, 08:18 AM
  #227
FNBADAZ06
FNBADAZ06's Avatar
Or, just box the whole thing up and send it my way and you custom fab something up
Old 09-12-2018, 12:16 PM
  #228
double06
double06's Avatar
Default There you go
Nice air box.
Old 09-12-2018, 03:27 PM
  #229
Innovate
Innovate's Avatar
Do it, that would be perfect.
Old 09-12-2018, 05:36 PM
  #230
jammeejamm
jammeejamm's Avatar
you cut that intake and you sir are straight up the most no ***** given bro i have ever seen on the interwebz!
The following 2 users liked this post by jammeejamm:
HC Mechanic (09-21-2018), Millenium Z06 (09-17-2018)
Old 09-12-2018, 06:47 PM
  #231
Josh B.
Josh B.'s Avatar
LOL, thanks. I think that award goes to Jayyyw though.
The following 2 users liked this post by Josh B.:
HC Mechanic (09-21-2018), jayyyw (09-16-2018)
Old 09-12-2018, 06:58 PM
  #232
JesC6Z
JesC6Z's Avatar
I tried looking for it on google but maybe u can if you dig a little deeper. 956 resin with capaseal powder mixed in. They use this on composites on our military aircraft where I work. A friend of mine helped me with a small repair on the rocker panel and also mixed strands of fiberglass from cloth mixed all in with the 956. I’d assume it work great on carbon as well. Let me know if you need any help finding it
Old 09-13-2018, 01:57 AM
  #233
Josh B.
Josh B.'s Avatar
Is there an easy to use epoxy, like the two-part side by side syringe thing from 3M or JB Weld? I know they make stuff for plastics and composites, I just can't figure out which kind. Or anything else that's easy to use would be helpful. Dries clear would be nice too.
Old 09-13-2018, 06:22 AM
  #234
MickVette
MickVette's Avatar
St. Jude Donor '13
I used this when I cut apart my air box and glued it back together. It is black though. I had to clamp the pieces in place until it dried but it dried very strong. I'm not sure how it will hold with CF.
Amazon Amazon
Old 09-13-2018, 08:24 AM
  #235
double06
double06's Avatar
You know if you cut it exactly right you can flip it 180 degrees and the snout will be shooting up instead of leveling off. You have enough cord there to have your MAF on passenger side.
Old 09-13-2018, 10:57 AM
  #236
Josh B.
Josh B.'s Avatar
The shape isn't perfect oval, more like a hamburger, arched over the top, flat on the bottom, so a cut and flip would not work. Also too long. Also too small diameter at the end. Its 4" and I need it to be 4.5" at minimum for the Southways 108.
Old 09-13-2018, 11:37 AM
  #237
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Hmmmmm, hamburgers.
Thanks for meeting up for dinner last night. It was fun. I'll take you for a great burger in AZ when you come out.
Josh B. (09-13-2018)
To Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
Old 09-13-2018, 11:44 AM
  #238
Josh B.
Josh B.'s Avatar
Originally Posted by Unreal
Hmmmmm, hamburgers.
I had a great time man! The Burger was good, and it was nice to be near the ocean for a bit. Definitely, they also have Culver's in AZ somewhere. One of my favorite franchise burger places.
Hopefully both our cars will be back together soon and we can meet up at a half mile in AZ.
Old 09-13-2018, 01:32 PM
  #239
MTPZ06
MTPZ06's Avatar
My concern with cutting it (aside from cutting that work of art) is that it will no longer have a sealing edge, or lip, as it does now. In fact, its tapered...so getting a worm drive/band clamp to properly tighten and hold a silicone coupler in place is going to be challenging. I can see it wiggling itself loose all the time as the car gets driven.
Old 09-13-2018, 01:56 PM
  #240
Josh B.
Josh B.'s Avatar
That's a definite possibility, but I could always use a mild adhesive to keep things in place. The silicone will contour to the taper, but yeah, a clamp on a taper is not ideal. None of this is ideal, but working with what I got.
Quick Reply: [Z06] Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
