C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
Old 09-20-2018, 09:17 PM
  #261
Innovate
Innovate's Avatar
Morimoto lights? Not a fan. Cup Wheels will look dope and carbon ZR1 bits will be nice. I would not do any aero due to you wanting to do half-mile with the car and you will slow down.
Awesome on the progress, definitely interested on seeing this done.
Old 09-20-2018, 09:21 PM
  #262
Josh B.
Josh B.'s Avatar
That's why I wrote that I'd do aero later on, because of the drag.
Old 09-20-2018, 09:37 PM
  #263
Innovate
Innovate's Avatar
Maybe I should read. I saw pretty ZR1 and thought about that.
Old 09-20-2018, 10:10 PM
  #264
Mordeth
Mordeth's Avatar
Received 1,678 Likes on 878 Posts
2018 C6 of Year Finalist
St. Jude Donor '10, '17
In testing, I lose about 5 mph on the back straight of WGI due to the very small, inconsequential wing on my C6Z. On my C7Z with the rear wicker added I lose 8 mph. In the highest position I lose 12 mph. The wicker produces much more drag than the wing due to it's inefficient shape. All else being equal, drag grows exponentially with speed and therefore the amount of drag is not only growing but accelerating as you go faster(this is bad). And since drag is proportional to the square of speed, the power needed to overcome that drag is proportional to the cube of speed. So you need expend larger and larger amounts of power to overcome drag as speed increases. At that point, the shape, position, construction and angle of the airfoil becomes exceedingly important, as you can reduce the impact of drag while maintaining similar downforce simply with a more efficient design. I use a top mounted, swan neck style wing on my C6Z with large endplates and an integrated gurney channel....all of which create downforce more effectively and efficiently than a wicker/spoiler. It's always a trade-off though. Downforce, however desirable, is rarely free.
Old 09-20-2018, 10:24 PM
  #265
Josh B.
Josh B.'s Avatar
Awesome info. It makes sense that GM went to a wing on the C7 ZR1 for a bit more efficiency in achieving rear downforce. Which reminds me, I asked you awhile back about removing my airdams under the front fascia. I'm going to unbolt the sides and cut and remove the center one with a razor blade.
jayyyw (09-23-2018)
Old 09-20-2018, 11:44 PM
  #266
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
I did that to my Z, Josh, removing the outer two pieces and essentially cutting the centyer to half level.. When I installed my 4" brake cooling ducts from the front grill and no longer needed to have the high pressure under the front fascia to direct air into the brake cooling. If you are just doing straight line events, removing all of the air dam will be OK. I do road course work and left about half of the center part to create some negative pressure behind to draw air thru the radiator. For road course work, that did not generate enough flow thru the Dewitts radiator on 100* days for cooling (245* water, 290* oil) which is why I went with the LG hood to get improved cooling thru the radiator without having to suffer the front end lift at high speed.
Old 09-21-2018, 01:06 AM
  #267
Josh B.
Josh B.'s Avatar
Awesome info. I'll cut it off then since I'm mostly straight line and gotta have that mph.
Old 09-21-2018, 07:38 AM
  #268
Mordeth
Mordeth's Avatar
Yes, remove the sides and cut down the middle. If you are concerned over temps, you can cut the middle down to roughly in half or so (height) and leave the length the same. In that one particular spot you want to slightly disrupt the air flowing under the car as it will create a high pressure area in front of the dam which in turn creates a low pressure area behind it to pull hot air out the bottom of the engine compartment. It adds a tiny bit of drag, but in my opinion might be worth the trade-off if temps are a concern (and as you know I hate drag and lift so I only create it when necessary).
If you don't have any cooling issues then cut the whole thing off and be done with it. At the track, no one has that silly air dam on their car (either removed or cut down significantly).
Due to the very small, easy to conceal and relatively inconsequential wing on the rear of my car ( ) I need to run significant front aero to balance my car, so I fabricated an extended front splitter out of ABS and run a full undertray almost to the pan as well as dive planes (canards). Not suggesting you go anywhere near as radical as me but know that the C6Z suffers from front end lift at speed and so anything you can do to mitigate this (like ditching the air dam) is useful.
And here is me at around 150mph. You can see the wing doing serious work (compression on the rear) and the front aero is balancing it adequately. I have literally hundreds of high speed pics of my car and am continually making adjustments based on what I see from the these pics and from the telemetry I gather. I had added wing angle for these particular tests.
The following 2 users liked this post by Mordeth:
HC Mechanic (09-04-2022), yur2slo (09-21-2018)
Old 09-21-2018, 08:47 AM
  #269
MickVette
MickVette's Avatar
St. Jude Donor '13
Great information and pictures illustrating the effects. I have a question about the rear bumper cover. Looking from under the vehicle, the rear bumper cover looks like a parachute to me. Did you have to do anything to keep air from filling that area?
You have a rear wing? Didn't notice. LOL
Old 09-21-2018, 11:44 AM
  #270
Sled Driver
Sled Driver's Avatar
What wing? I must need my eyes checked.
Old 09-21-2018, 12:23 PM
  #271
double06
double06's Avatar
You might want to do a cam sensor while you are there. After 10 years, mine the plastic ballooned (.015) I had to pry it out. New one went in with no force.
Josh B. (09-21-2018)
Old 09-21-2018, 12:40 PM
  #272
Josh B.
Josh B.'s Avatar
Good call. Pretty sure my cam sensor was a PITA when installing the 454, too. Yeah, probably due for a new one.
Old 09-21-2018, 12:44 PM
  #273
ramairws6
ramairws6's Avatar
Excellent advice! I ended up pulling my timing cover last year because I couldn't get mine out without destroying it. What a PITA!!
Old 09-21-2018, 02:01 PM
  #274
Da Z06
Da Z06's Avatar
Do you have some pics of this? I'm unable to visualize for whatever reason.
Old 09-21-2018, 02:24 PM
  #275
Josh B.
Josh B.'s Avatar
lol. Can hardly notice it.
Old 09-21-2018, 02:46 PM
  #276
AzDave47
AzDave47's Avatar
If you mean the 4" brake ducts, see this link that Jim did and helped me:
https://www.corvetteforum.com/forums...-new-look.html
If you want to do this, PM me your normal e-mail address and I can give you expensive info plus parts list. I have sent my info to probably 20 or more forum members.
Old 09-21-2018, 04:55 PM
  #277
HC Mechanic
HC Mechanic's Avatar
Is there an easy to use epoxy, like the two-part side by side syringe thing from 3M or JB Weld? I know they make stuff for plastics and composites, I just can't figure out which kind. Or anything else that's easy to use would be helpful. Dries clear would be nice too.
I’ve got a bunch left over from doing my 102 intake mods, I got you Marine!
It took me a week or two of working with the epoxy to figure out how to mix and apply very neatly so the touch up requirement is minimal to none. Once you’re all set I’ll drive out and help you do it, or I can handle that portion all together for you. You’re the master when it comes to the fab work, YOU GOT THIS! Get to cutting Brother!
To Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
Old 09-23-2018, 07:56 PM
  #278
Josh B.
Josh B.'s Avatar
After chatting with Jayyyw and now Carlos (Da Z06), we are working out how much timing advance to put in the engine. Here is what I am seeing on desktop dyno 5, take the estimated hp figures at face value. They've been accurate for me in the past, I'm using and sharing them now only as a reference for A to B comparison of timing advance.
The old top end is completely removed. Disassembly is over.
Now for all the good stuff!
Zero Advance
+1 Advanced
HC Mechanic (09-23-2018)
Old 09-23-2018, 08:37 PM
  #279
JesC6Z
JesC6Z's Avatar
Zero Advance
+1 Advanced
good lawd man is that HP at the tire? 825 N/A
Old 09-23-2018, 08:39 PM
  #280
Josh B.
Josh B.'s Avatar
Most values are crank hp, but if you look in the second red column of the DD5 screenshots you can see it as "wheel hp" too.
Quick Reply: [Z06] Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
