C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
Old 09-23-2018, 09:34 PM
  #281
JesC6Z
JesC6Z's Avatar
That’s badass my dude can’t wait for the numbers and crank up. Keep the updates coming
HC Mechanic (09-24-2018)
Old 09-24-2018, 12:28 AM
  #282
HC Mechanic
HC Mechanic's Avatar
Can’t wait to hear this baby sing!! ArrrrRAH
Old 09-24-2018, 08:18 AM
  #283
jayyyw
jayyyw's Avatar
+1 degree seems like the ticket.
Old 09-24-2018, 08:30 AM
  #284
double06
double06's Avatar
This should be very interesting on how the numbers turn out from the program to real life. Looks like desktop dyno has come a long way, I like all the variable inputs.
Old 09-24-2018, 08:33 AM
  #285
jayyyw
jayyyw's Avatar
FWIW, the program Da_Z06 uses was within 1hp from what my car made when he plugged in the numbers.
Old 09-24-2018, 09:32 AM
  #286
edmundu
edmundu's Avatar
Originally Posted by Josh B.
Most values are crank hp, but if you look in the second red column of the DD5 screenshots you can see it as "wheel hp" too.
Damn, Josh!!! Cannot wait to see this thing go in the 1/2, 1 mile events. This is NA to a whole nother level
Old 09-24-2018, 11:42 PM
  #287
Josh B.
Josh B.'s Avatar
Busted out the degree wheel and locked down the timing at 113* ICL. Advanced 1*.
Old 09-25-2018, 06:25 AM
  #288
MickVette
MickVette's Avatar
St. Jude Donor '13
Can the timing be adjusted in 1/2° increments? Just curious because 1 1/2° would put you right in the middle of the peak numbers on the calculated dyno results.Or does the cam chain stretch etc. move the timing toward the 2° direction?
Old 09-25-2018, 08:22 AM
  #289
double06
double06's Avatar
I wonder if mezzarie will come out with an LS water pump with the hose on the other side like the 2009 and later cars so the pesky water pump hose isn't in the way of the intake tube (also heats up intake tube). Of course with your high ram not so much of an issue.
Old 09-25-2018, 12:59 PM
  #290
Josh B.
Josh B.'s Avatar
The Hex A Just cam sprocket I use can be infinitely adjusted +/- 6*, so half a degree is no problem. I went with 1* advance based off most of the feedback, but you're right too. 1.5* would be nice as well, but the red loctite is on the bolts and torqued down so I'll just leave it at 1*.
MickVette (09-25-2018)
Old 09-25-2018, 01:06 PM
  #291
Josh B.
Josh B.'s Avatar
Yup, would be nice if it were on the driver side like 2009 and later cars. I use a thermal sleeve on the radiator hose to combat this. Oh, you were right about the cam sensor. Mine was ballooned and had to be broken out in two chunks. Like $20 for a new AC Delco replacement.
Old 09-25-2018, 01:29 PM
  #292
MickVette
MickVette's Avatar
St. Jude Donor '13
I read where there is a procedure once the cam sensor is replaced that involves bring the engine to fuel cutoff or something like that. Is this true? I wouldn't want to have to do that on a beast of an engine like yours.
Old 09-25-2018, 01:31 PM
  #293
Josh B.
Josh B.'s Avatar
Crank relearn. Slowly and smoothly go to WOT until fuel cut.
Old 09-25-2018, 02:10 PM
  #294
MickVette
MickVette's Avatar
St. Jude Donor '13
That's a lot of rpm with no load. Thank you for confirming. I feel I should replace the sensor in my 2009 due to age alone.
Old 09-25-2018, 05:03 PM
  #295
Da Z06
Da Z06's Avatar
Looking great!
This thing is going to be a beast and we are just overly excited to see it alive and causing panic!
#HiRamMafia
Old 10-06-2018, 03:26 AM
  #296
Josh B.
Josh B.'s Avatar
Piston to valve radial clearance was too low, .048”. PTV axial was around .240”. So I did not need to flycut necessarily, but I needed more radial. So I decided to sand roll the intake valve reliefs with a 2” sanding drum on my die grinder.
Final radial clearance came out to .137”, so plenty of room for things to move at high rpm.
Ordered up some Trend 7/16” 8.700” .165” wall pushrods.
Its going to start coming together fast now. Getting excited.
Old 10-06-2018, 08:43 AM
  #297
double06
double06's Avatar
Josh do you think it was the heads themselves or are you running a 2.25 valve which may have been more of the issue?
To Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
Old 10-06-2018, 11:31 AM
  #298
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
Expect any impact on balance?
Old 10-06-2018, 12:11 PM
  #299
Josh B.
Josh B.'s Avatar
The valve location moved 0.080” with the All Pros. Valve grew .025” radially.
Old 10-06-2018, 01:02 PM
  #300
Josh B.
Josh B.'s Avatar
Just gonna send it
The following 2 users liked this post by Josh B.:
HC Mechanic (10-08-2018), jayyyw (10-07-2018)
Quick Reply: [Z06] Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
