[Z06] Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
#302
Oil pump and front cover are on. Finished the valve reliefs with some final sanding on the edges. Also finished the pass side coil relocation. Had to narrow up the overall width to make sure there’s room for the door swing. Dropped in the lifters, using a special grip as to not damage anything. Modified the LG airbox/ ram air scoop because it had been jutting out of the grill.
DualQuadDave (08-02-2023)
#305
Head and manifold party are next.
#306
Man...grinding on pistons would scare the sh*t outta me.
jayyyw (10-11-2018)
#309
Pushrods measured. Going to order some Manton dual tapered 7/16” pushrods. Headers are on. This was a major pain because the All Pros are drilled for 3/8”-16 exhaust manifold bolts, so I had to team out the holes in the header flange. I used a stepped bit in an air ratchet in order to fit the right confines without removing the headers from the car.
Balancer is on.
Both coil brackets mounted.
Balancer is on.
#310
Getting there when do you think you will have it done? I know you got a few parts on order.
#311
Like the new cam sensor.
#312
Progress, buddy !!!! CAn't wait to see it fire up
HC Mechanic (10-20-2018)
#314
Thanks man. No. After speaking to Ryne Cunningham about the car and my goals I decided to have him tune the car. There’s a couple niche things we’ll be doing with the new combo that Ryne has experience with. Plus he is local and an awesome guy and you can’t beat that.
#315
I’m waiting on some parts. Hopefully sooner than later but you know how it goes. I’ll order up my pushrods Monday. Probably route my oil feed lines to the valve covers for the spring squirters. Lots of -4 line and fittings to do that.
#316
She’s coming along nicely Brother! Let me know if you need a hand with anything
#319
I was really enjoying this thread, wonder how someone puts this much time and effort into this and then disappears for 6 weeks. Some more crazy **** must have happened?
#320
HC Mechanic (12-04-2018)
