[Z06] Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
#121
I bought some of the new Comp Billet Valve Covers to spruce up the new top end. They come with valve spring oilers built in, so I'm looking forward to keeping the valve springs nice and cool for the street.
ICT Billet Coil relocators. Custom 48" MSD 8.5mm plug wires with high heat boots.
#123
I may grab a set of them if my holley talls don't work, but don't want to go through trouble of mounting my coils elsewhere.
#124
They are drilled for some VC mounted coil brackets that are available separately. I really like the VCs. I picked em for $540, which is comparable to bare billet VCs, and these are black anodized billet AND with valve spring oiling, even ARP bolts. So I was pretty sold.
HC Mechanic (08-16-2018)
#125
For a minute you had me with that first picture, I didn't realize you were going to go with dual cams, Josh!
... then the disappointment of just fancy valve covers in the boxes.
#127
... but how unique would a DUHC engine be?
#128
Wow those look baller.
#129
Those are pretty slick.
#131
Hellcat 525lph Fuel Pump
Same external dimensions as the F90000267 450lph pump. Outlet increased from 10mm to 11mm. I’ll see if my 3/8” hose will still slip over it, pretty sure it will.
#133
In Austin all next week. Maybe I should do some vette stuff while out there.
#135
I believe the F90000285 is actually slightly longer than the 267/274. The cost difference definitely isn't worth the marginally increased flow though.
Bad_AX (07-24-2018)
#136
I want the dyno to be able to never come close to overheating during steady state, and I wanted the ability to handle anything that may ever come near it.
I'm actually in Austin for the weekend for a friend's bachelor party.
#137
Looking great Josh! The research you have done will payoff!
#139
It's worth it for my application. If I'm on the edge with the 450 and I don't really want any future power gains, I'll be happy with just the 525 as a "next step". I don't want the cost or complexity of a dual pump module and a controller. Hopefully there will be no issue running the Hellcat pump on a steady diet of ethanol.
#140
