Rear O2 sensors...are they heated?
Curious if the rear O2 sensors are heated? My tuner recommended keeping them connected as sometimes you can still trip error codes. I'm trying to find the best place place them and my options are a bit limited if they generate heat when connected.
every tuner removes them even the well known ones so might as well.... less weight=faster
Keep them in so your emissions system looks complete but have the tuner disable them in the calibration.
Zero reason to leave them in. If your tuner has 1/2 a brain he can set it so everything is good, no codes, and no issues.
This recommendation was given to me by Pat G, and I'm pretty sure he has a little more than half a brain. According to him, removing them works almost all of the time, but keeping them plugged in works all of the time with no exceptions.
Thank you all for the info. That's a bummer that they're heated so I'm going to just try to disconnect them and hopefully I won't have any tuning issues. I'd rather not have some heated sensors floating around the engine bay and it seems like they always burn up if routed to their post cat location.
