C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
WCCH Stage 2 LS7 heads, report after 18-20K miles
Old 07-18-2018, 11:57 AM
edmundu
edmundu's Avatar
Originally Posted by FNBADAZ06
Has there been others who have pulled there heads and sent them in for inspection ?
WCCH did the heads originally, so going back to the same vendor works for me......I trust Richard and his recommendations
I did. Mine had about 7.2k miles on them, and the intake guides were all fine. The exhaust guides were "slightly" worn from what I was told.
WCCH stood behind their work, and discounted the guide related work, and I picked up the tab for the assembly/disassembly, valve job, seals, hot tank, shipping, etc...
My setup was a RR punisher cam, trunioned stock rockers and all supporting mods to make 608/525 sae corrected. It regularly saw 7.1-2k rpms
Old 07-18-2018, 12:06 PM
FNBADAZ06
FNBADAZ06's Avatar
Deb/Richard told me the same deal.....they would take appropriate actions to address any work (if required) and discount accordingly, as I'm a repeat customer too
You made the same general power I did, and comparable RPM operating environment.
Old 07-18-2018, 02:44 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Originally Posted by MTPZ06
Yeah, I just thought for a data perspective it may be interesting for some of us to see...given its Katech cams, the Katech spring package, and I believe they (Katech) recommends swapping in new springs at 20K for preventive measures. I'm sure their 20K recommendation is very conservative, but it would be interesting nonetheless to see how the springs would fair after that mileage.
For sure. I checked my C6 Z06 at about 17,000 miles of street with occasional track day and they were only a few pounds off PSI's new spec.
__________________
Contact:
(e) zach@katechengines.com
MTPZ06 (07-18-2018)
Old 07-18-2018, 02:49 PM
FNBADAZ06
FNBADAZ06's Avatar
I'll see if anyone local has the equipment to test my old springs for me, which had approximately 13K miles on them.
Old 07-18-2018, 04:33 PM
Dirty Howie
Dirty Howie's Avatar
Its ok to trust the best ....................
DH
Old 07-18-2018, 07:43 PM
cseaman
cseaman's Avatar
subbed! also at 20k on my WCCH
Old 07-18-2018, 09:48 PM
MarkC
Support Corvetteforum!
MarkC's Avatar
C2 of Year Finalist (performance mods) 2019
Me too, 15K on my Vengeance, WCCH rebuild. Rest of engine is stock.
Old 07-19-2018, 05:23 PM
CaddyRacer
CaddyRacer's Avatar
in for results
Old 07-19-2018, 10:26 PM
rio95
rio95's Avatar
So if you find that your heads didn't hold up worth a crap you're going to try the same setup again??? I guess if u plan on doing that every 15k that works. Seems odd to me tho!
Old 07-19-2018, 11:23 PM
FNBADAZ06
FNBADAZ06's Avatar
The new owner of the heads can make that decision after the facts have been presented. I posted the cam shafts I used with the heads so people can see what lifts were used, and if those lifts can cause a significant amount of side loading that accelerates the guide wear.
I don't know if anyone has had a set of heads equipped with Moldstar's or any other available guide material that's been inspected after 18-20k miles of abuse. My post is just to present the measurements and the other relevant valvetrain facts, then go from there
I have a new build that is going together that I may post the details about when the project nears completion, and that build will contain aftermarket heads and matching valvetrain.
Old 07-19-2018, 11:40 PM
rio95
rio95's Avatar
Ah I missed the part where you weren't keeping the heads. Makes sense.
Old 07-19-2018, 11:45 PM
FNBADAZ06
FNBADAZ06's Avatar
I really didn't post that information as I didn't think it was really relevant , but to be completely transparent, I am moving to a new setup with aftermarket heads regardless of the outcome of the inspection
Old 07-20-2018, 11:37 AM
  #33
FNBADAZ06
FNBADAZ06's Avatar
Heads arrived at WCCH yesterday afternoon
Hopefully we get some numbers early next week.
The following 3 users liked this post by FNBADAZ06:
Frankie15 (07-20-2018), MTPZ06 (07-20-2018), rainman750 (07-21-2018)
Old 07-20-2018, 02:52 PM
  #34
ratomicZ06
ratomicZ06's Avatar
subd. I too have wcch, k501 w 15k miles. Maybe 20 drag passes and plenty of 7k pulls. Ill be pulling covers soon.
thanks for starting this relevant post!
Old 07-20-2018, 02:57 PM
  #35
sublime1996525
sublime1996525's Avatar
for results.
Old 07-20-2018, 03:31 PM
  #36
FNBADAZ06
FNBADAZ06's Avatar
This is a very popular combo, so I knew it was going to be very relevant to a number of members here
For reference for those who run a different cam, here's the cam card for the K501 so you have something to compare to...
Katech K501 camshaft card
Old 07-20-2018, 05:12 PM
  #37
AzDave47
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
Victor, thanks for the K501 cam card. I did not have that before.
Dave
FNBADAZ06 (07-20-2018)
To WCCH Stage 2 LS7 heads, report after 18-20K miles
Old 07-20-2018, 05:15 PM
  #38
FNBADAZ06
FNBADAZ06's Avatar
Dave
Did CPR not give it to you when you picked up the car after the install ?
Old 07-20-2018, 05:17 PM
  #39
AzDave47
AzDave47's Avatar
No.
Old 07-22-2018, 08:52 AM
  #40
jayyyw
jayyyw's Avatar
*gasp* Mamo top end? *gasp*
Quick Reply: WCCH Stage 2 LS7 heads, report after 18-20K miles
