C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Heat shield falling apart
Old 08-19-2018, 01:17 AM
Z LIFE
Z LIFE's Avatar
Default Heat shield falling apart
So the heat shield above my torque tube is falling apart.. don't know if I should be worried about it? I was thinking about removing it but I wasn't to sure. Any suggestions?
Has anyone else had this problem
Old 08-19-2018, 02:04 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
Assuming the intent of the heat shield is to keep the interior cooler, insulation under the carpet is more effective.
IMHO anything that is falling apart needs to be removed.
Old 08-19-2018, 08:37 PM
Z LIFE
Z LIFE's Avatar
Default .
I'm worried that it'll burn
Old 08-20-2018, 09:51 AM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
Do you know what model/manufacturer it is?
It should be replaced, not just removed.
Old 08-20-2018, 06:18 PM
Z LIFE
Z LIFE's Avatar
Default .
No I do not.. i looked but doesn't say anything. I figured GM since its factory heat shield/insulation
Old 08-20-2018, 08:14 PM
AzDave47
AzDave47's Avatar
I thought you were talking about the tunnel plate. The OEM tunnel plate is just aluminum sheet. I guess you are talking other insulation.
Old 08-20-2018, 08:23 PM
Z LIFE
Z LIFE's Avatar
Default .
It looks like both. It has an aluminum sheet about as thick as a sheet of foil on the insulation.. if that makes any sense
Old 08-20-2018, 08:40 PM
AzDave47
AzDave47's Avatar
My 09 2lz Z06 OEM tunnel plate is sitting in my garage. It just is a sheet of aluminum, no insulation. When I did my HCI work I had a mid-grade Elite Engineering tunnel plate installed. That does have additional insulation.
To Heat shield falling apart
Quick Reply: [Z06] Heat shield falling apart
