Carbon Fiber ZR1 Spoiler from RPI Designs!!!
Platinum Supporting Vendor
2005-2013 C6 Corvette ZR1 Carbon Fiber Rear Spoiler
Adding the great look of Carbon Fiber to your C6 Corvette should not break the bank! Our real carbon fiber rear spoiler looks great and does not cost a fortune. This rear spoiler is similar to the factory ZR1 spoiler that comes on the C6 ZR1 from the factory but it has been made about a half an inch taller. This spoiler is a no-drill installation. Just remove your factory spoiler and replace it with Carbon Fiber spoiler. The included double sided tape makes for a no hassle installation. This rear spoiler is made out of real carbon fiber and features a high clear coat finish.
The rear spoiler is an aerodynamic component that can be used alone or in conjunction with other aerodynamic components to improve the overall efficiency of a vehicle's aerodynamic package. The rear spoiler integrates with the vehicle's rear deck to help reduce rear-end lift and increase high-speed cornering grip. This will help increase downforce and reduce drag when used with other aerodynamic components (i.e. side skirts, front splitter, etc.).
Features:
This vehicle-specific component is designed to match the contours of the vehicle's rear deck area, for a factory-like fitment. With Carbon Fiber Construction it is formed in the autoclave at high temperatures using impregnated carbon fiber manufacturing processes, for high strength and low weight. The Carbon Fiber rear spoiler has a UV Resistant Coating that is finished with UV-resistant clear-coat paint for resistance against various environmental conditions (take care of this as you would take care of your vehicle's paint finish - polish then coat with good-quality wax or synthetic protectant).
Website Link: https://www.rpidesigns.com/shop/item...-rear-spoiler/
Use Coupon Code RPICHRIS5 for Immediate Savings!!!
Features:
Fitment: 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013 C6 Corvette
We are currently out of stock on that item. Here is another option for you that should be available early January: https://www.rpidesigns.com/shop/item.aspx?itemid=3271
Let me know what you think.
Thanks,
Chris
