[Z06] Cam retainer bolts almost got me
Curious if the linked ARP bolts will even work on an LS that needs countersunk? Is there an LS7 specific part number?
This is one reason i just went and found grade 8 bolts at the hardware store. I was actually shocked they had the correct 8mmx1.50 machine head bolts but they did.
I could only find arp bolts in the old 10mm bolt style like ls1,2,6 engines use
maybe someone thats used then can post the correct ls7 part # for us
No your correct they both use/say t40 plus
The at I balancer instructions for the 9 bolts that attach the pulley to the hub is where I first saw the "plus" in relation to the torqx bit
Btw those balancers are nice. I went ahead with the 8rib so I wouldnt have to upgrade when I find a blower
