C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Any guys run a full exhaust versus just a xpipe and dumped? Has anyone done a good comparison to see if there is power gains? I have ARH 2inch headers with off road xpipe and corsa exhaust. I can get rid of the exhaust and probably lose about 30 to 40 pounds and may make me gain a little bit of power. I’m sure it will be louder but I like that I’m just curious the sound will have a good tone or will it be just nasty sounding.
I’d doubt there’s much to be gained by eliminating the axle back section since it’s a true 3” system. Cheap and easy to make a couple turn downs off the x pipe to see though.
I run a dumped x-pipe. I don't know what gains there are to be had but I'm sure eliminating those last 2-3 bends is good for something. You'll drop 50lbs losing the Corsa exhaust. I did it for the weight savings.
It's loud but I think it sounds great. I have Magnaflow mufflers welded into the x-pipe and then turn downs in front of the axles. I'd say the drone is comparable to a Borla or B&B bullet system.
I would probably Will have no mufflers and just Have turn downs
