C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] HPR 468 LS7, WCCH Brodix BR7 heads, and G1Pro custom billet intake build
Old 12-09-2018, 08:19 AM
  #161
double06
double06's Avatar
Default C5R Blocks
Originally Posted by colanut
What do you guys think about the c5r blocks.???
They are very expensive and you have many more options today to chose from. Dart, RHS, LS Block with Darton Sleeves. Also depends what you are doing, an NA motor is much less in need of all the bells and whistles than a 1200 hp forced induction motor. I am not a C5R block expert someone could chime in but do they have accessories mounts for the AC etc. like the regular block.
Old 12-09-2018, 09:12 AM
  #162
441LSXTT
441LSXTT's Avatar
Originally Posted by Innovate
I have a coating for that. I use IGL Wheel on just about everything lol. Coating it will keep in the new look and keep the elements out that will oxidize and corrode that intake.
what is IGL? Sorry if that was a dumb question. so if I use the IGL wheel on the intake it will help it stay clean?
Old 12-10-2018, 09:46 AM
  #163
0HP RESEARCH
Former Vendor
HP RESEARCH's Avatar
Not sure if they are really needed that much anymore given the number of sleeved options and the LS7 block itself. The "REAL" C5R block had aluminum cams, Ti hardware and a number of other things that you won't see in the one sold to the public. Given the relative low power output of the real race cars in legal trim they could do stuff like that since it wasn't being pushed that hard either RPM or HP wise.
All depends on what you are after really. Sometimes a sleeved 5.3 block is just fine, other times you might have to look aftermarket Aluminum or Iron depending on the goals.
Old 12-10-2018, 01:46 PM
  #164
NSFW
NSFW's Avatar
IGL makes coatings:
https://iglcoatings.com/category/automotive/
Old 12-11-2018, 08:38 AM
  #165
double06
double06's Avatar
Any ETA on dyno world? Anybody want to make some guesses? I am thinking 700 hp and 600 tq at the tire. I think the 600 rwtq will be tough to get but we shall see.
Old 12-11-2018, 08:44 AM
  #166
441LSXTT
441LSXTT's Avatar
they started the car up last night. All I can say by listening to it over the phone it definitely sounds a lot healthier and a lot deeper sounding than my H/C/I LS7. My builder said it sounded like a big block. So it is definitely getting closer. I think we should all play the guessing game and have some fun. I’m hoping 700rwhp 630rwtq.
Old 12-11-2018, 08:49 AM
  #167
jayyyw
jayyyw's Avatar
What are the cam specs? Compression? Heads? Header size?
Old 12-11-2018, 08:54 AM
  #168
441LSXTT
441LSXTT's Avatar
cam is 260’s/270’s....740’s/740’s....112LSA
comp is 13.1 (running straight e85)
heads WCCH Brodix BR7 heads
headers ARH 2inch headers off road xpipe (no cats)
Old 12-11-2018, 10:15 AM
  #169
Che70velle
Che70velle's Avatar
695 hp 578 tq
Old 12-11-2018, 10:17 AM
  #170
jayyyw
jayyyw's Avatar
Old 12-11-2018, 10:48 AM
  #171
441LSXTT
441LSXTT's Avatar
My H/C/I LS7 made 625rwhp 555rwtq (BTR4 can,AI heads 12.1 comp and 2inch ARH headers)
Old 12-11-2018, 01:25 PM
  #172
FNBADAZ06
FNBADAZ06's Avatar
What injector are they going to use for you ?
Old 12-11-2018, 01:27 PM
  #173
441LSXTT
441LSXTT's Avatar
I think 95lbs
Old 12-11-2018, 02:21 PM
  #174
441LSXTT
441LSXTT's Avatar
708/586
i would be be happy with that. Hope tq will higher then that
Old 12-11-2018, 02:28 PM
  #175
FNBADAZ06
FNBADAZ06's Avatar
I think 95lbs
OK, was wondering. I'd be interested what the duty cycle ends up looking like on E85. I just purchased some ID1050x's for my setup as I was worried about the 60 lbs Seimens Deka's not being enough.
Old 12-11-2018, 03:30 PM
  #176
441LSXTT
441LSXTT's Avatar
These are the same injectors on my other set up that made 625rwhp on e85 and my tuner said there was plenty more room to make more power
Old 12-11-2018, 04:02 PM
  #177
FNBADAZ06
FNBADAZ06's Avatar
You may have had bigger injectors than me....and I was 605 RWHP and 510 TQ, with the MSD and NW102 tb...1 7/8th B&B lg. I was on E54 with the 60 lbs.
I think Anthony said that Louis G tried the 60 lbs on his test mule 468 and ran out of fuel at 5800 rpm
To HPR 468 LS7, WCCH Brodix BR7 heads, and G1Pro custom billet intake build
Old 12-11-2018, 04:10 PM
  #178
441LSXTT
441LSXTT's Avatar
I think Jeremy said that Louis G tried the 60 lbs on his test mule 468 and ran out of fuel at 5800 rpm
Yeah I do have 85lbs. I just checked. So I should have enough injector to support 700rwhp n/a
Old 12-11-2018, 04:41 PM
  #179
FNBADAZ06
FNBADAZ06's Avatar
Old 12-11-2018, 04:51 PM
  #180
0HP RESEARCH
Former Vendor
Its always better to err on the to big side than just right...seen a few cars pickup a bit of power just by going over board a little on injector sizing to cut the spray time down.
Quick Reply: [Z06] HPR 468 LS7, WCCH Brodix BR7 heads, and G1Pro custom billet intake build
