C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
GSpeed HPR 468 dyno results [and video]
Old 10-04-2018, 04:06 PM
GSpeed
Supporting Vendor
GSpeed's Avatar
Default GSpeed HPR 468 dyno results [and video]
Original Build thread:
https://www.corvetteforum.com/forums...ace-setup.html
This engine was built for a few reasons, one of which was for NASA TT/ST competition. The car it was slated for had a functioning LS7 in it, and its purpose changed from a NASA car to an SCCA car mid summer, and the 468 was no longer legal. We know a lot of you have been awaiting the results for this engine, and we finally had the opportunity to do so.
As (bad) luck would have it, our customer and fellow competitor Troy Messers #176 NASA TT1 car had a coolant anomaly that we could not solve. The engine ran well, but it had a case of the "self filling" drysump tank which we have seen in the past, yet a 100psi on the block did not leak and we were out of time. NASA Nationals was less than a week away, and trailer load in and setup was 72 hours away.
In steps the 468. Its been on the shelf for several months awating its turn, quietly whispering "put me in coach" all season. This engine is special to us for several reasons, so it needed to be under constant supervision, or data analysis to verify plugs, lambda, and tune up are all as intended.
You can read about Troys car here: https://www.corvetteforum.com/forums...equential.html We did not finish the thread, perhaps when things settle down that will happen.
With out further adieu- Dyno sheet:
Tune up specs-
Motec M150 controlled, Development ECU with GPRP based Paddle shift control
.89 target lambda
22*ignADV peak tq, 27* peak power
NGK TR7 plug
MS109 fuel
MSD intake
NW102
4" inlet with bellmouth
17/8 headers, 3" catbcak
Notes: Crank case pressure was still less than ideal- engine has a 3 stage dailey drysump and the motec recorded .25 psi peak crank case pressure. This combo was slated for a 5 stage, but time did not allow anything but the already fitting 3 stage. There is 15hp in crankcase vacuum.
Emco sequential gearbox robs rwhp in the range of 20 at the least to 30 at the most. We see this time and time again on all the cars we work on as they must be dyno certified for NASA. We plan to redyno with an H Pattern before the end of the year.
For this power, we are very happy given the circumstances. We can bench race it to death, but it will make over 700rwhp with a better driveline and some crankcase vacuum. for what its worth, it maxed out the OEM injector at 5000 rpm. We all know what a stock injector can make, and when it was all said and done the ID850s were roughly 50% idc. We tried to change injection timing, but it didnt pick up power. We will experiment with larger injectors and less injector duration next time.
We have a lot more cool projects in the work trying to make the legitimate 700rwhp club more popular. Thanks for Tuning in, yall are the reason we do stupid stuff like this
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
HP RESEARCH (10-11-2018)
Old 10-04-2018, 04:20 PM
FNBADAZ06
FNBADAZ06's Avatar
Hell yeah !!!!! Thanks for that update, Louis !!!
Old 10-04-2018, 04:32 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Damn, what a beast!
Old 10-04-2018, 04:34 PM
Innovate
Innovate's Avatar
SR cam?
Old 10-04-2018, 04:40 PM
GSpeed
Supporting Vendor
GSpeed's Avatar
Gentle marine hydraulic. Nothing exotic, nothing you would not consider hopping in and driving cross country in.
Old 10-04-2018, 07:12 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Amazing and good work. Keep it up buddy.
Old 10-04-2018, 07:37 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
Sorry. I may have missed it, what manifold do you have on that motor??
Can you disclose how much overlap that cam has? How about the c.r. .. can you share that?
Old 10-04-2018, 07:38 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
glad to see your still around bro! 👍
Old 10-04-2018, 09:03 PM
JesC6Z
JesC6Z's Avatar
Mother ****** that torque!
Old 10-04-2018, 09:22 PM
GSpeed
Supporting Vendor
GSpeed's Avatar
it has a stock untouched MSD.
Camshaft overlap 30ish*
compression is 11.5ish. It’s designed to run on 93 pump fuel.
Old 10-04-2018, 10:03 PM
Turbo2L
Turbo2L's Avatar
Good grief. A rowdy NA cam, a decent intake manifold, 2 points more of compression, and some E85 and I'd be in love.
Old 10-05-2018, 01:39 AM
Josh B.
Josh B.'s Avatar
Congrats on the solid results Louis! It's been an awesome build to follow along with. So much more potential with this platform should you decide to go after more with it.
Old 10-08-2018, 11:44 PM
441LSXTT
441LSXTT's Avatar
Awesome the numbers. They are in the process of building my 468 but we are shooting for a max naturally aspirated street car. Goal is 725rwhp
Old 10-11-2018, 10:53 AM
0HP RESEARCH
Former Vendor
HP RESEARCH's Avatar
Very nice work guys. Keeping in mind it's a stock intake, smallish headers, hyd roller with no more than 0.650 lift that could be ran in a daily driver and still pound out a winning TTU lap at NASA nationals....I'd say it did very well.
The following 2 users liked this post by HP RESEARCH:
RGT (10-11-2018), Silver Bullet C6 (10-11-2018)
Old 10-11-2018, 03:47 PM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
Say it isn't so Louis.... The MSD hasn't been MAMOFIED.....?
Shot in, Shot out... Great Job Louis! Keep it up... Will I see you again at the upcoming WGF event?
Old 10-11-2018, 07:55 PM
GSpeed
Supporting Vendor
GSpeed's Avatar
we are planning on it! Hopefully with this engine in something else....
Operations (10-11-2018)
Old 10-15-2018, 11:42 AM
0HP RESEARCH
Former Vendor
There are more 468's in process now both for retail customers and Louis, all with slight changes to them so we should start to see a good bit of published results. Jeremy's build should be nice as well with a bigger lift hyd roller and custom intake manifold. Maybe even a High Ram 468 in process too from Louis?!?
Old 10-15-2018, 05:04 PM
jayyyw
jayyyw's Avatar
Now I'm in love!
Old 01-04-2019, 04:14 PM
0HP RESEARCH
Former Vendor
I think this puts into perspective just how much more average power the HPR 468 really makes over most stock and H/C/I 427's.
Stock LS7 data pulled from a few posted here online, DynoJet SAE corrected
LS7 H/C/I pulled from a few posted on CF again using DynoJet SAE correction with typical bigger headers, MSD, 102, higher compression.....some have made more, most less.
To GSpeed HPR 468 dyno results [and video]
Quick Reply: GSpeed HPR 468 dyno results [and video]
