Time for valve guides, and a few upgrades while I'm in there
#41
Tuning was fairly easy but I attribute that to the Halltech 103 maf forward design - keeps the pulses away from the maf sensor which will cause surge. Idle there is not enough overlap to give a false lean like more agressive cams - my bet is that it is right on the edge as it is very easy to pull a little fuel and have it misfire. Cruise areas I am on stock timing map.
I idle at 900rpm with a more agressive spark correction vs stock.
Not sure if the +4 made a huge difference down low but I certainly love the powerband. I am close to 12:1 cr and the reduced torque down low (from cam events vs stock) allows me to put it to the ground easier now than before coming out of corners at track and on street. Powerband starts to hit hard around 4000 rpm and Torque peak is at 48-5800rpm. It then reduces from there but carries strong through to 7200+ giving ~600whp (~440tq) Its not a torque monster but sure carries well into the high rpm. I have fuel cutoff at 7500rpm.
Now that I've spent some time researching camshafts and working with Steve, I have a few questions about your cam shaft if you don't mind:
Looks like you have 18° of overlap, How difficult was that to tune and drivability under 2000 rpms? What RPM did you end up with at idle? Did putting it at +4 make the lower rpm tuning nicer? What RPM does the power flatten out at?
#42
St. Jude Donor '13
I have the Halltech 103mm and I was able to tune out the minor surge it had. When I built my own forced air intake using most of the Halltech 103, surge was pretty aggressive. I was able to tune further and tame the surge, but am currently considering the Halltech MF108 in hopes of softening the air "signal" so I can keep some form of my forced air intake with a larger overlap camshaft.
I also have fuel cutoff at 7500 and idle is at 925rpms.
#43
St. Jude Donor '13
Got oil analysis results today. Wondering if I should do the bottom end. What would you guys do?
#46
You are most welcome haha Over the years I have learned not to fix what isnt broken. Worst case it gets worse and you need a rebuild...best case nothing happens! So may as well chance it.
#47
St. Jude Donor '13
I already have the heads off and rebuilt as well as a cam change, motor mounts etc. I'm already this far so if these numbers are questionable this is a good time for a fresh short block.
The lead has me worried. I'm more of a preventative maintenance type then the run to failure type.
#48
St. Jude Donor '13
I replaced the blurry pic of the Blackstone Labs report a few posts up with a picture you can actually see the numbers (sorry about that). I was concerned with lead being 10 with only 1300 miles on the oil. Heads are currently off the car and I was preparing for a camshaft, oil pump, timing chain and balancer replacement. I will pull the engine, break it down and inspect the bearings, rods and other internals while I'm in there.
#49
#50
Good thread and informative, interesting how the K501 has greater lift than the other 2 cams and they are all within 2/2 of each other. As a car with a big cam, yes you lose the lower RPM torque a little bit (I still make big torque though). around 38-4k RPM's the car becomes a ballistic missle. I still spin at low RPM's though.
Also curious about the GT21 cam with the huge lift, I have heard those are bad for our cars with stock rockers.
#51
St. Jude Donor '13
Your camshaft has 29° of overlap if I saw correctly. WOW!!! How was tuning and highway cruising? I like the fact you can still spin the tires at low rpms and 38-4k rpms coming to life is pretty sweet not like a 5500 on/off switch like a 2-stroke power band. At what rpm does power start to fall off?
I am still deciding which camshafts I want to try depending on how difficult changing them will be with a 2 piece timing cover I recently ordered. I have been working with Stave from CamMotion and he has been great. They will pretty much build anything we can dream up. I started building a spreadsheet to compare driving impressions with different lifts, duration and LSAs. I know there is a lot more to camshaft characterization than that and I already need a 3 dimensional chart to loosely accurately view the differences. I am willing to give up some low rpm torque to spread the power into the mid 7000 rpm range. A lot will depend what I find when I pull the short block apart which direction this project takes and how my tuning skills are as I step up into bigger overlap camshafts.
I saw the GT21 camshaft and was wondering the same thing. That is one of the camshafts I plugged into the DeskTop Dyno and knew the results didn't properly reflect that camshaft. I can't even imagine the loads on stock rockers with that much lift.
#55
I run a 243/258 .660 114+3 camshaft. Makes great power and drives fine. Peaks at 7200 rpm with a Holley Hi Ram. Made 646/555 on a dynapak dyno. I've been able to spin the tires in second gear, around 5-10mph, and smacking the throttle. This cam has 22.5 degrees of overlap.
I will be moving to a 263/275 .666 115 camshaft with 39 degrees of overlap. Should move my peak up over 7500rpms and make huge power in the mid-upper range.
I'd definitely stay away from that GT camshaft. It has an absurd amount of lift for no reason and older, harsh, lobes.
#56
Cutting fuel for a rev limiter seems like an easy way to lean out a motor at high RPM, no? If the ecu can handle the spark management, why not just use that?
#58
St. Jude Donor '13
The 263/275 is a HEALTHY bump in camshaft size! That is going to be a blast to drive and make some nice power!
The GT was a nice comparison cam and gives a good idea how much piston to valve clearance is there.
Kinda stinks I moved away from Austin. It would be cool to see your set up.
#59
I found some limitations of the version DeskTop Dyno version that I have (cheapest one). I plugged in all the values of known camshaft with dyno chart and "fine tuned" the program to make the dyno charts match best as possible when I started comparing camshafts. As I started comparing more and more camshafts outside of the sizes I was looking at I found the program doesn't really take into account for lift and duration accurately when comparing with known dyno charts. The program does look at LSA a lot more accurately but I must admit the calculations I performed on the DeskTop Dyno are not accurate. It was a fun tool to play with but I guess I needed to spring for the more expensive version.
My cam is 248/262 .651/.646 113+3. Power starts to fall off after 66-6700 RPM's. I have not been back on a dyno after the new mods and clutch so I have no idea now. I also have the car apart replacing lifters and going Cometic .040 HG's to bump compression to 12:1. Then the car with get tuned and I will strap her on the dyno then.
If your program does not account for lift, I would definitely take results with a grain of salt. Lift matters.
#60
Your 243/258 cam sound like a fun driver. What was the idle rpm? Could it cruise in 6th? Did you have to drive around the rpm range where most healthy cammed LS7s surge at lower speeds?
