C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] All New Forgestar D5 Drag Wheels- Flow Formed - Bead Knurling & Bead Lock- Corvette
Old 11-01-2018, 06:01 PM
OwensRacing
OwensRacing's Avatar
These wee posted on Facebook
VibeMotorsports (11-01-2018)
Old 11-01-2018, 06:04 PM
VibeMotorsports
Supporting Vendor
VibeMotorsports's Avatar
More from Forgestar D5 Drag Wheels
Old 11-06-2018, 07:23 PM
VibeMotorsports
Supporting Vendor
Originally Posted by Cajun @ Edgyvette
Ordere my set from today! I highly recommend purchasing your setup from Vibe. Nuff said!
Thank you,
The D5 Drag wheels do clear and work on steel brakes but NOT on carbon ceramic brakes.
Confirmed by Forgestar today
Old 11-07-2018, 01:51 PM
VibeMotorsports
Supporting Vendor
We are now open for Pre-order !!
Make sure to give us a Call or Email to be on the first container that's coming soon.
1-800-814-8423 x104 forum@vibemotorsports.com
Old 01-16-2019, 02:43 PM
Sean_C
Sean_C's Avatar
Still no weights on these huh??
Old 01-16-2019, 03:28 PM
VibeMotorsports
Supporting Vendor
I can get them for you now, what size do you need ?
__________________
ALL TOP NAME BRANDS ONLY A PM, EMAIL OR PHONE CALL AWAY !
Office 800.814.8423
forum@vibemotorsports.com | Corvette Wheel Specialist
Old 01-16-2019, 03:41 PM
FNBADAZ06
FNBADAZ06's Avatar
Weights on 17x11 for both bead and non bead ?
whats available in 18" front and rear for a C6 Z06 ? Weights on them as well.
Old 01-16-2019, 03:49 PM
Sean_C
Sean_C's Avatar
I'm mainly interested in the non bead lock 18" wheels....but I'm sure the whole forum would appreciate all the c6z wheel weights if u have them
Old 01-16-2019, 06:41 PM
VibeMotorsports
Supporting Vendor
Gathered information from the first sets that came in shipped from Forgestar
18x5 - 18.45lbs
18x10 - 20.75lbs
18x11 - 23.35lbs
Beadlocks
17x10 - 20lbs
17x11 - 22lbs
Old 01-16-2019, 06:45 PM
Sean_C
Sean_C's Avatar
18x5 - 18.45lbs
18x10 - 20.75lbs
18x11 - 23.35lbs
Beadlocks
17x10 - 20lbs
17x11 - 22lbs
Is it true the 17x5s fit up front over stock c6z brakes?.... Cuz if that's true it would be awesome to run 17x5 up front and 17x11 out back
Old 01-16-2019, 06:50 PM
VibeMotorsports
Supporting Vendor
Yes, The fitment is confirmed to work.
17x5-26
17x11+43
The first batch is here in 2 weeks, and second batch should be third week of Feb. 2019.
Old 01-16-2019, 06:52 PM
Sean_C
Sean_C's Avatar
17x5-26
17x11+43
Wow that's awesome!!!....what are the weights on the 17x5s and 17x11 non bead locks?
Old 01-16-2019, 06:56 PM
  #33
VibeMotorsports
Supporting Vendor
Front what has been gathered fronts are 17lbs & rears 22lbs
Old 01-18-2019, 11:43 PM
  #34
DirtyC7
2nd Gear
DirtyC7's Avatar
Hey,will these fit a base c7? thanks!
Old 01-19-2019, 01:09 PM
  #35
VibeMotorsports
Supporting Vendor
The front will not work, but they have 17x10.5+65mm for the rear to work.
Old 01-19-2019, 01:12 PM
  #36
DirtyC7
2nd Gear
DirtyC7's Avatar
Thanks so do the fronts fit the c7z?
VibeMotorsports (01-23-2019)
Old 01-23-2019, 07:06 PM
  #37
VibeMotorsports
Supporting Vendor
Yes, that's correct brother.
To All New Forgestar D5 Drag Wheels- Flow Formed - Bead Knurling & Bead Lock- Corvette
Old 02-04-2019, 11:34 AM
  #38
Sean_C
Sean_C's Avatar
Vibe do u guys have for sure weights on the c6z 17x5 fronts and non bead lock 17x11 rears?
VibeMotorsports (02-04-2019)
Old 02-04-2019, 12:58 PM
  #39
VibeMotorsports
Supporting Vendor
we have a couple sets coming over this week, ill post the weights as soon as i get them.
Old 02-04-2019, 04:37 PM
  #40
Sean_C
Sean_C's Avatar
Thank you that would be much appreciated
Quick Reply: [Z06] All New Forgestar D5 Drag Wheels- Flow Formed - Bead Knurling & Bead Lock- Corvette
