Great new product from Comp, BSR Rocker setup
Direct from Billy@Comp, the engineer that designed them. All over his facebook, not sure if it is public, or if you have to be his friend.
Da Z06 (11-02-2018)
Link to Billy on FB
Why does that not surprise me?
Will be interested to see if these would change equation with push rods and valve springs.
https://m.facebook.com/story.php?sto...00002730422469
Wouldn't change push rods, and if anything, would allow a lighter valve spring since they have better control over the valves.
Pushrods
As long as they use same rocker arms and the mounting point circle or shaft is same diameter as stock should be the same or really close. Will be interesting to see but seems to be a proven design and could should have been done by factory.
Torque sequence
Should be interesting on how they handle this as some rockers will be at or near full lift. With the singles you wanted it at or close to zero load. This is a proven design with other cars but maybe because load is spread out not so much an issue.
#33
I may at some point, but not initially. I am pushing the lift limits of my stock rockers at .660" and I like that this setup gives me a little more room for lift and a more stable valve train. My OEM rockers have been fine, but this seems like a better setup for those of us that are at the upper whp limits of what the LS7 is capable of.
The following 3 users liked this post by Michael_D:
#35
#36
Nice idea. Now if they get around to making their SPR radius tip rockers bodies for an LS7, and mate those to this shaft design...that would be an effective solution for the masses.
#39
As for why didn't someone do this earlier, that is exactly what he said after testing it. It isn't something new.
MTPZ06 (11-02-2018)
#40
Total lift for my latest iteration is .675".
How does the LS7 version mount? Is it a direct bolt on, or is machining of the pedestals still required? And no lash adjuster on these either.
Cool product, but clearly inferior to the Crower system. I wouldn't feel bad if I were you. I most certainly do not, and will still use the Crower system unless lifts are lower than .650.
