Great new product from Comp, BSR Rocker setup
#141
Stand up peeps over there at Comp. Unreal has some connections over there and they were happy to call and have me check a few things. Shorter push rods are needed which i kinda figured right after installed them. These are for a stock application or possibly will work with a different setup then mine. I run BTR stage 3 cam,Morel lifters and stock rockers bushed. 7.775 length pus rods. So anyone going to run these check lash as most likely not bolt on and go. Im sure i wont be the only one that runs into this. Either way from what i can tel its a solid set up. Ill be getting shorter push rods and get it going.
Thanks UNREAL for speeding this up.
#142
Yes keep us posted on the difference in pushrod length from what you got now.
#143
#144
This is completely backwards from what they advertise for this product. I wouldn't be interested in something like this then, especially after spending 300$ on tool steel custom pushrods. Why else would I be looking for a stock rocker arm geometry? This doesn't make sense. Did you measure the difference mayracn?
#145
Unreal got me into contact with engineering and we have been communicating on the issue. I may a freak deal here as no one else has reported any problem.
#146
Guessing ill need 7.700-7-.750 length. Getting a few sets to test out.
#147
rajahhindi (03-11-2019)
#148
Ill just say its def gonna be possible to need new push rods. Was my impression stock rocker in stock location so would not need new push rods. I was wrong.
Also so many different combos. Decked heads to lifters choices. Just between those could be .060 difference.
#149
I wouldn't be surprised if pushrods needed some tweaking if you are using a lifter with a tight window. Prob "ok" on something like an LS7 lifter
#150
But why does that matter when it worked fine with his original bushed OEM rockers? The bottom line is you shouldn't need new pushrods with the same rocker at the same pivot height. Why do people keep forgetting this?
#151
Pushrods
That's why I said double check to make sure you didn't get ls3 version in an ls7 box. Check the rockers compared to your stockers.
#152
This is why i didnt feel i needed to check lash. Still not getting what changed.
#153
reading all this and it seems some are going to be the guinea pigs for the product/company - going to be interesting reading down the road - good and bad I'm sure
#155
I decided to return this kit. I have bought other products that are new to the market and more times then not there are issues, so I decided that it wasn't worth my time or effort.
#156
I follow the amazing Billy Godbold on FB as well.......... he's the guru there at Comp and is the man when it comes down to valve train dynamics. He shares so much info about the products, testing, and engineering, If you're on FB, you can follow the thread where Nick inquired about your issues
https://www.facebook.com/billy.godbold
#157
Yep, Billy is who I talked too about this and made sure it was resolved. Great guy.
#159
Check him out on FB....it''s worth it , as he lives and breathes valve train dynamics
#160
Has anyone ever gone through an checked every valve for push rod length? I am curious what the range is. It would be easy if you could buy or rent 8 push rod checkers an do one side at a time.
