Prop shaft help
Prop shaft help
I was taking my car apart to install my new clutch an noticed the pilot bearing was bad and so is the prop shaft. The prop shaft has a nasty groove in it. What is involved in replacing the prop shaft? I see a new one is about $500 but what else is needed? Any friendly instructions?
Should replace guibos at the same time. Gotta pop the torque tube out.
Rubber couplers that it attaches too
Guibos...They're the (2) rubber couplers at either ends of the driveshaft.
Not to be confused with Guidos...
