C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
What’s the heigh of you Z?
Old 11-12-2018, 09:28 PM
jorge18
jorge18's Avatar
Default What’s the heigh of you Z?
I dropped my car this weekend using the stock bolts and it doesn’t look like it came down much. I’m wondering what’s the height of everyone’s car? I’m talking about from the floor to the fender.
Thanks!
Old 11-12-2018, 10:56 PM
HouseS2k
HouseS2k's Avatar
Thanks!
Get lowering bolts or trim the bushings off the factory bolts.
Old 11-14-2018, 07:18 PM
Sleazy Rider
Sleazy Rider's Avatar
just finished doing my suspension and coil over shocks on my 2007 Z. front height is 25 3/4" and rear height is 27" from the floor to the fender well. it has 3/4" between the top of the tire and the lip of the fender well on all 4 corners.
Old 11-15-2018, 05:30 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Factory height on my 09 Z06.
front 25 & 15/16"
rear 27 & 1/8"
Old 11-15-2018, 06:47 PM
HouseS2k
HouseS2k's Avatar
I finally went out and measured mine, 25” front 26.5” rear.
Old 11-17-2018, 12:02 AM
ZR1Cat
ZR1Cat's Avatar
My ZR1 is at stock height. Golly stock height is low enough for all the cringe worthy scraping and dragging sounds I get when carefully driving around. Why make it worse? I've got other things to do. I see no practical or functional reason to lower the car further.
Old 11-17-2018, 12:11 AM
HouseS2k
HouseS2k's Avatar
the scraping sounds you hear is the flexible rubbed air damn under the front of the car. Owners manual states it’s normal to hear scraping. They don’t serve a cooling benefit only aero. Unless you plan on doing 190, remove them. I tossed mine day I took delivery of my z06.
Old 11-17-2018, 09:39 AM
Z.06
Z.06's Avatar
Default Ride height
I never adjusted my 2008 Z06 ride height from the new condition at museum delivery. As far as I can remember, it was always low and would scrape at every opportunity. So now it is 10 years old, and when I run it on a road course with the OEM wheels and stock size tires, it more than just rubs the flexible air dam. In fact, it scraped the front brake air diverters off twice and tore the left inner rear fender out twice. Measuring the height of the fenderwell at the four corners over the centerline of the wheel hub, I found my car was 25.75" high at the front and 27.43" high at the rear. So was this a low build height or have the OEM springs sagged? Who knows? I have had the DRM Bilstein shocks on my car, practically since new (best mod ever!). My springs are still stock.
While not wanting to raise the ride height of my car excessively, I had to stop tearing the bottom bits off, so I raised the ride height to 26.5" front and 27.7" rear, also getting the suspension stagger closer to what Chevy recommends. These heights seem to work fine. I can feel the rear end of the car moving around more in hard cornering though.
Anyway, for anyone who might want to use their car on a road course, you might want to think twice before you make the car super low.
Old 11-17-2018, 11:29 AM
HouseS2k
HouseS2k's Avatar
i would agree 25.75 in the front is pretty low from factory. Have you had the car aligned after raising it? Also being that you do road courses your leafs could be worn. Low mileage used ones can be had pretty cheap.
Old 11-17-2018, 05:19 PM
Sleazy Rider
my 25.75 front and 27 rear is about 1+" lower than when i started. just measured the heights of a friend of mine and his were 27.125 front and 28.5 rear and his are factory untouched.
Old 11-17-2018, 09:06 PM
Al_Scrap
Al_Scrap's Avatar
Cut stock bolt.
Old 11-18-2018, 11:28 AM
Z.06
Z.06's Avatar
Going in for an alignment, hopefully Tuesday. Regarding road course track days, I had two in 2016 one in 2017 and 14 since April 2018. But my car has been very low (as evidenced by scraping noises over speed bumps) since long before 2016, and there was no track time before then. Here is my car at museum delivery in 2008. It doesn't look low at that time. So maybe the springs sagged with age more than track time. I feel the same way. It is a fact that I am not as tall now as I used to be. Actually track time makes me feel younger.
To What’s the heigh of you Z?
Quick Reply: What’s the heigh of you Z?
