[Z06] 19" Front Spyder wheels
I know this is a long shot, but...
Can you take the OEM rear 19" Spider wheels and cut them and weld them narrower to fit on the front - or is the offset still an issue?
I know there are companies that will widen a wheel by cutting and welding so I assume they can also make a wheel thinner by removing material and welding.
Would really like to move to 19" front and was wondering of this was possible without having to go to the Cup wheels as I prefer the look of the Spyders.
Thanks in advance
Thanks in advance
Look up Weldcraft. I had them widen a set of wheels for my Camaro that turned out fantastic. Beautiful welds and easily balanced. I'm pretty sure they can narrow wheels as well. Not sure if the offsets are an issue though
Hirohawa (11-13-2018)
