C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Anyone use nutserts when installing their side skirts
Old 03-17-2019, 12:44 AM
03Zcrit
03Zcrit's Avatar
I Wound up installing the side skirts and used 3/16 large head exploding (star) rivets and did a test drilling one out with a 3/16 bit and it was so easy. It would take longer to remove those plastic screw rivets than it would to drill out the rivets. For the people on the fence I would recommend the exploding rivets as they are very easy to both install and remove.
Old 03-17-2019, 01:09 AM
CamarosRus
CamarosRus's Avatar
Those Black Large Head Exploding Rivets seem like the BEST Fastener for the job.....
and fairly easy to remove.........
Old 03-17-2019, 06:42 AM
HouseS2k
HouseS2k's Avatar
i can tell you this, I’d have both skirts off before you could get 5 of those rivers drilled. It’s literally no comparison for installation and removal. Working on cars isn’t a hobby for me, It’s my profession.
Old 03-18-2019, 12:38 PM
ExtremeOnlineStore
Supporting Vendor
ExtremeOnlineStore's Avatar
I am considering adding side skirts but would like to be able to remove them if damaged without having to drill out all the rivets. Has anyone put their skirts on with nutserts?
Check out our C7 Collection for more Exterior Parts & Accessories NOW. Self-tapping screws will be included. You will able to remove the side skirts by drill off the screws.
https://extremeonlinestore.com/collections/corvette-c7
Old 03-18-2019, 02:41 PM
CamarosRus
CamarosRus's Avatar
HouseS2K, The Plastic Rivets you use are NOT the Exploding Style Aluminum Head
I'm searching the Internet for Plastic 3/16" Rivets??
Old 03-18-2019, 03:15 PM
HouseS2k
HouseS2k's Avatar
Swordfish 63905 Nylon Blind Rivets for BMW 51-71-7-002-953-2 Package of 25 Pieces
Amazon Amazon
Old 03-18-2019, 04:45 PM
Apocolipse
Apocolipse's Avatar
Received 1,278 Likes on 923 Posts
People dont trust screws when you are spending 400 bucks a tire...
Old 03-21-2019, 05:38 PM
CamarosRus
CamarosRus's Avatar
HouseS2k, I believe youve shared the BEST choice for securing Skirts to Rocker Panels and I dont see
why this searching and discussion has to go on and on and on.............
But I am curious with all your BMW experience etc etc , WHY would not one of the expandable plastic
screw in or push in retainers work well......and removing might be easier than the Rivet ????
I'm also asking WHY in all this Skirt Fastener Discussion has no one mentioned the misc fasteners
required to secure the OE Flares (Mudguards) to Edge of Qtr Panels as using "SCREWS" into the Fiberglass
is just WRONG!!!!!!!!!!
On the BELOW pic I dont understand how the ZR1's use that Push In Expanding device
as when I remove the Hex Head Screw from my Grand Sport there is a White Nylon "piece"
that takes a Thread Screw............
Old 03-21-2019, 08:25 PM
HouseS2k
HouseS2k's Avatar
In my experience, I believe the reason BMW uses the rivets over push clips is due to wanting something to be semi permanent over removable. We use the rivets all over the place, especially on the plastic fender flares on the SUV’s. They hold wayyyy tighter than a push clip. It maybe a consumable, but it holds way better.
CamarosRus (03-22-2019)
Old 03-22-2019, 08:16 PM
CamarosRus
CamarosRus's Avatar
HouseS2k, I am going to order the BMW "Swordfish" Rivet" as linked below
Amazon page states that Flange Diameter is 20mm which is Quite Large and
in my case may not fit properly against skirts with my pre-drilled Holes.....
We shall see ?????
Amazon Amazon
Old 03-22-2019, 08:22 PM
HouseS2k
HouseS2k's Avatar
We shall see ?????
https://www.amazon.com/dp/B01BON79A0...iglink20400-20
ill do you a favor and snap a picture in a minute and post it.
Old 03-22-2019, 08:56 PM
HouseS2k
HouseS2k's Avatar
Bmw rivets fit perfect in the spaces.
CamarosRus (03-23-2019)
Quick Reply: [Z06] Anyone use nutserts when installing their side skirts
