[Z06] Low mile C6 Z06 engine blown up
#41
Looks like your OE oil cooler has failed (which can happen)...but unless it leaked out most or all of the oil in your engine, its not the root cause of your engine failure.
#42
Greg
#43
That sounds really low to me, but anyway, I agree with your idea that going to a reputable tuner/engine builder is probably gonna be cheaper (and better). My friend's 08 C6Z had bearing failures at 20k miles, I believe he paid $20k or $21k at the dealer for the new motor + labor + 2 year warranty. He had electrical issues that popped up after.
#44
So what is the end result? What did you end up doing?
Greg
Greg
#46
Sorry for the delay. About to make another post now.
#47
Update: An intake valve in cylinder #3 broke. Looks like it completely snapped off. The intake rocker also broke on cylinder #3, and my spark plug on that cylinder is damaged. It looks like something smashed into it. The cylinder #3 sleeve is broken all the way. It appears this is where all the coolant came in. Coolant ended up getting into all the cylinders, probably because it made its way into the oil system, which then brought it into the rest of the engine. The broken valve also smashed into the piston once it broke.
So my engine is completely destroyed. Please see the pictures below.
Broken intake valve on cylinder #3
Head showing broken intake valve on cylinder#3
Cracked sleeve in cylinder #3
Broken rocker on cylinder #3
Parts from broken rocker on cylinder #3
Banged up spark plug from cylinder #3
Flooded with a mix of coolant and oil
Landru (12-18-2018)
#49
Resleeve block and replace head and piston ?
Or, find a used block or complete short block, as you see then for sale all the time.
#56
They actually didn't charge me. I'm guessing it's because they didn't do any other diagnosing than what I already did (checking coolant, oil, etc). They weren't able to tell me where it was leaking from. A friend of mine helped me out with getting my car to a shop that his friend runs, so hopefully this week we'll have a true diagnosis.
Man, I'm sorry to hear that! Luckily for this particular car I've had it at a few amazing shops. I did reach out to AHP. They were extremely kind and offered to do the diagnosis for me, but because of how busy they are, they said they wouldn't be able to actually fix the car until February. Therefore I decided to keep my car here closer to me. Otherwise it would've went to them in the beginning. Thanks for the well wishes, I wish you the same!
You mean the shop that did my heads? It's AHP. I've been chatting with them, and they've been very nice and helpful.
Yeah, that's what it sounds like. I did check out his blocks on his website. That's probably the route I'm going if I need to replace my block. A shop more local to me is going to do the tear down now. Wish AHP was closer, but this shop should be really good as well.
What is the reason exactly? I hope I'm not causing you any additional worries about your own car. I made sure to post this after I got an official diagnosis (or rather when I thought I did). That way I could just say what the issue is, get some advice on how to proceed, and then I could proceed. Turns out my original diagnosis was incorrect, so now I feel I posted too early. Oh well, I guess these things happen.
I also keep little information in my profile on purpose. I'm a private person when it comes to posting on the internet. I've mentioned the area I live in (Southern California).
About the roller comment, I mentioned that because I didn't want to spend almost 20k on fixing the car only to sell it for low 30s when maybe I could save myself a ton of stress and sell as-is for 15 or maybe even more (meaning I would be out the same or less than if I would fix it).
The pictures I have won't tell much because no one has taken apart the motor yet. All I have are some pictures of some oil coming out of what looks like the air filter area of the car. If you or anyone else is interested, I could post those. I just didn't think they'd add any value. I also tried taking pictures of inside the coolant tank.
#60
Zero reason to have a dealer do anything unless it is under warranty. They will gouge the hell out of you. (rare expections like Abel in Norcal). So get it to a corvette shop and go from there.
