How do we see manual trans temperature?
I very recently did a clutch change so my battery was disconnected for 3 weeks. Car started up fine an is running fine, no check engine light. BUT..... my electric fan is running when it should not be. Oil an water temps are reading fine but I dont know if fans are running because of maybe trans temp. I could have damaged the probe or connector. I did do an trans fluid bypass of the radiator by just connecting the two lines together with a compression fitting.
thing knower
the dash logic unit can provide that info with a little tweaking
-drew
-drew
Another dashlogic guy here. Now I just need to neard out on getting it to do all its capable of doing. Ethanol content is high on my list.
