40k mile LS7 tear down
Just wanted to share these for anyone curious on what wear looks like on an 06 LS7 @41k miles
Oil pressure was 36-40 hot idle and 70+ wot
Had metal flakes in oil after taking heads off to do a lifter swap
Oil pump has weird marks I can't explain
Three rods had a small mark that looks like slight wear
The bearings to me seem to be the source of glitter I had
That’s nuts to see on only 40k. All these horror stories about the ls7 arent making me feel better. I don’t understand how the ls1 can be rock solid (just hit 102k in my T/A with no issues) but this bad a$$ gem of a 427 seems to have so many problems.
Mine also has pixie dust in oil. I just did a second cam swap hoping it’s just the cam bearings adjusting to new cam or from the assembly lube. I’m at 43k
thing knower
hmm... im about to send a sample on a stock 65k mile motor....
this is what my oil filter has in the bottom, waiting on a Blackstone.. the light streak is a finger swipe
I didn't know they made oil with a pearl in it. :o
Best of luck with the oil samples. I was told over and over to run the motor and flush the oil basically by a bunch of people. This just didn't seem right to me. I sold my other C6Z and missed it a lot so I bought another. This is really making me kick myself in the *** since I drove this car once. Now I need to decide what's next. Do I buy new pistons and reuse crank with a set of dimpled third gen Ti rods and have them coated? Do I swap rods crank and pistons? Idk
Definitely a shitty situation to be in. Like I said, I've never noticed anything in my oil but I could have just missed it. Never really looked at it that hard. I'm selling my motor and the guy wanting to buy it asked me to send out an oil sample. The results will decide how the next few months will go. If it comes back bad, I will likely tear down the shortblock and reuse the stock crank/rods if they are in good condition and throw in some forged pistons.
And what was the Problem?? I can't see anything it looks be good or not?? You have no issues with the engine??
you opend it the engine it has metall flakes ??
how do you drive the car ?? Track ? 3 honk races?? Or to the ice cream parlor ?
Subbing. Fully support filtermags. Great product. Keeps that fine particulate out of circulation (as long as it's a ferrous metal). It does look like you had some rather large particulate run through the bearings creating the deeper scoring. Good thing you preventively tore it down and found these problems before they got out of hand. You saved all the big parts from destruction so you can re-use all of them. There's a mixed set of feelings about recoating the stock rods and reusing them. My opinion...need to know the budget and the power goals before deciding on parts.
Good news: Your crank journals looks perfectly fine and they will polish out nicely. And the main cam journals looked good as well. The rods also "looked" good to the naked eye, but better to have them thoroughly inspected by a good shop before using. This is the perfect time to throw a bottom end in there that suits your needs.
St. Jude Donor '13
MTPZ06 (12-10-2018)
Agree with the above statement and also a fan of magnets even though there isn't much ferrous metal in our engines. I have been using these drain plugs with very strong magnets, not the cheaper weaker ones. I pick up quite a bit of magnetic "fuzz" each oil change from both drain plug magnets. I figure every bit helps.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
DH
The scoring on the outside of the oil pump MAAAYYY have been caused by over torqueing the balancer causing the timing chain to rub??? Just throwing guesses out there. Especially, it being a reputable shop that did the work. Hard to say without having the whole engine to look through. Does the valvetrain have the same scoring?
