C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Something wicked this way coming from HPR to the FNBADAZ06
Old 01-29-2019, 01:52 PM
  #121
BlindSpot
BlindSpot's Avatar
Received 1,360 Likes on 902 Posts
Originally Posted by FNBADAZ06
Hopefully some time in late spring.....I'll let you know
Even after I get the engine back and installed, I can't immediately go to dyno and tuning as I have a freshly rebuilt rear diff and gears that need break in mileage before I can lean on it.
NicD suggest I run the car on my original MSD/Injector/Intake combo for those break in miles, as my original tune for my K501/FlexFuel setup should be sufficient to get the car to run and idle.
After the break in mileage is done, I can drain all fluids with fresh stuff, then get it over to the dyno with the new injectors/intake/ etc. and go WOT
Please do. I want to just stare at it for a while!
Old 01-29-2019, 02:29 PM
  #122
Da Z06
Da Z06's Avatar
Originally Posted by Apocolipse
Very interested on this conical setup...currently running 1511 with Ti retainer but it HAS to be on the absolute ragged edge of control right now and would love a bit of extra headroom...cammotion lobes w/ 0.650 lift.
PSI1516LS is one badass spring.
Old 01-29-2019, 04:50 PM
  #123
Apocolipse
Apocolipse's Avatar
Received 1,278 Likes on 923 Posts
ooooooo
Did not know about these. Will dyno with the 1511 then swap to the 1516 and see if there is any change 6500+
Thank you
Old 01-29-2019, 05:30 PM
  #124
ls404fd
ls404fd's Avatar
ooooooo
Thank you
Are you hydraulic or solid roller? The 1511 is pretty light per the spec sheet.
Old 01-29-2019, 05:40 PM
  #125
Apocolipse
Apocolipse's Avatar
Hydraulic - johnson 2116 and Ti retainers on OE Ti intakes and hollow exh. Seems to rev to 7k+ no problem but never been on a dyno.
Old 01-29-2019, 05:57 PM
  #126
FNBADAZ06
FNBADAZ06's Avatar
I used the 1511's with the Katech Torquer 110 and K501, which I revved to 7300
Old 01-29-2019, 06:30 PM
  #127
ls404fd
ls404fd's Avatar
You could move to a dual spring like the 1206x but you're also adding more weight to the spring by doing so. If it ain't broke (or breaking) I wouldn't mess with it. The johnson lifters would take the stiffer PSI beehive if you want to give that a try too.
I'm building a pretty aggressive solid roller build with ~.715" lift and am planning to use the PAC 1208x with plans to rev it up to 7800-8000 rpm. I may step that down to the 1207x if PAC thinks I can get away with it. They list max lift at .700, but I know people are going beyond that - and the coil bind specs appear to be just fine. Worst case with an LS7 I can go a little taller on the installed height to sneak out .020" more lift.
Old 01-30-2019, 07:36 AM
  #128
FNBADAZ06
FNBADAZ06's Avatar
Looks like at minimum Comp 7228-16 conicals would fit the OEM LS7 heads....not sure about the other two listed here on Comp's site.
The conical they are discussing on running on mine are not listed yet and are too big for standard LS7 heads.
For comparison sake, here's PSI's 1500 Series catalog....
MickVette (01-30-2019)
Old 01-30-2019, 08:33 AM
  #129
Apocolipse
Apocolipse's Avatar
Thank you very much for the comp comparisson - certainly not worth the $ to take the heads off to be machined at this point so I am glad there are a few options outside of the duals. The basic comp is between the 1511 and 1516 as far as seat pressure goes but open is closer to the 1516. Only issue I see is coil bind from 1.8" is after 0.675" lift - I am 0.650" intake. How close are you going to run yours to cb or is that HPR secret material
Old 01-30-2019, 09:35 AM
  #130
FNBADAZ06
FNBADAZ06's Avatar
Erik and Billy (Godbold) are discussing cam and spring selection now, and have been bouncing ideas off each other. I don't think it will be any secret and I would certainly share the final configuration once it's been defined and tested if it's an off the shelf solution.
Old 01-30-2019, 10:49 AM
  #131
Apocolipse
Apocolipse's Avatar
Well if you end up going to cammotion for lobes it would make it easier on people like me haha
Old 01-30-2019, 11:20 AM
  #132
FNBADAZ06
FNBADAZ06's Avatar
I've watched and learned a bit with what Billy Godbold has been doing over at Comp Cams, and it is truly cutting edge stuff....he lives and breathes valve train dynamics and engineering, and is an educated nuclear physicist turned hot rodder
The Cam will ultimately come from Comp, with whatever lobe design they engineer/test to compliment my particular setup....no sense in trying to out smart a "rocket" scientist
Comp has three Spintron test rigs at their disposal, and if you subscribe to articles published in EngineLabs, EngineBuilders, HotRod Network, etc. you can read about what Billy has been doing, along with the testing and results.
Here's one about the Micro Surface Enhancement (MSE) finish which Comp (Billy) developed and tested....
https://www.enginelabs.com/engine-te...e-enhancement/
Old 01-31-2019, 05:39 PM
  #133
0HP RESEARCH
Former Vendor
HP RESEARCH's Avatar
Not sure how I missed your build thread but I'll try and chime in a bit more!
Old 01-31-2019, 05:56 PM
  #134
Apocolipse
Apocolipse's Avatar
please do
Old 02-01-2019, 07:44 AM
  #135
FNBADAZ06
FNBADAZ06's Avatar
You've got a lot of engines moving thru the shop...... too busy to be looking for build threads
Old 02-01-2019, 11:57 AM
  #136
0HP RESEARCH
Former Vendor
Well to touch pretty quickly on the new conical springs. There are more and more coming out there now and we might have found a conical to work with the higher lift setups, but it would have to be in an aftermarket head as they are to large to fit within the OE spring pockets. They do look to fit ok in the Brodix and TFS heads ok for sure, but still working on the details.
Now the big dual conical that Victor posted above, yeah that one is a big boy and would have to have the head cut for it, and also plan on running a lot of lift...and more than likely a solid roller just due to the pressures at setup with those. It is nice having a lot more options with springs now, just takes a bit more time to nail them all down.
The 7228 is more for the LS1/2/3 heads while the 7230 is what we have been using on most of the LS7 headed builds. They are tight getting in there on all of them so you do need to measure and make sure you have options for shims, locks, and retainer heights to get install where you need to be.
Old 02-01-2019, 12:04 PM
  #137
Da Z06
Da Z06's Avatar
To clarify, will the 7230 will fit a LS7 spring pocket?
To Something wicked this way coming from HPR to the FNBADAZ06
Old 02-01-2019, 12:12 PM
  #138
Da Z06
Da Z06's Avatar
ooooooo
Thank you
I rant the PSI 1516 to 7500 RPMs however my set-up was pretty light:
PSI LS1516ML springs
BTR TI-Retainers
Stock Locks
Stock Ti-Valves (intake)
COPO LS7 Hollow Stems Valves (exhaust)
Stock Rockers with Straub Bronze Bushings
So far weight comparison (based on my own scale) it looks like when compared to the PSI 1515 spring and Ferrera F2042P hollow stem.
Old Set-up (stock locks/retainer/intake valve/PSI 1515ML/Ferrera F2042P HS):
Intake: 164g (vs 179g stock)
Exhaust: 174g (vs 177g stock)
PSI 1516 spring, Ti retainer, COPO exahust:
Intake side weight: 149g (vs 179g stock)
Exhaust side weight: 147g (177g stock)
That is a 30g weight reduction or 16.75% on the intake and 30g or 16.94% on the exhaust over stock which was very significant.
Old 02-01-2019, 12:42 PM
  #139
0HP RESEARCH
Former Vendor
Yes, the 7230 will work on the OE LS7 or aftermarket LS7 heads that we have used.
Da Z06 (02-06-2019)
Old 02-01-2019, 01:58 PM
  #140
ls404fd
ls404fd's Avatar
I like the conical springs, and Comp is obviously very proud of them, but the max lift is depressing. .715" to coil bind from a 1.900" installed height
I guess it works well for most hydraulic setups out there, but I need something that will work on a stock ls7 head to ~ .725" lift on a low shock solid roller lobe.
Quick Reply: Something wicked this way coming from HPR to the FNBADAZ06
