Something wicked this way coming from HPR to the FNBADAZ06
#161
Former Vendor
That should go without saying, but I stopped during assembly to take the pic.....
Bearings are oiled inside the block and the cam is lubed as it goes in, and one more time through the crankcase (engine is upside down as you see) on each journal before it is put all the way in.
Lube is applied to the retainer plate, and also the backside of the cam gear. Loctite on all threads with CMD under the bolt heads to provide an accurate torque reading.
#162
Wow, I've never seen a cam that didn't have lobes! I agree, it would almost make sense to spec how long the valves are closed. I will be interested to hear it when you get it running, Victor.
#163
The cam is very similar in size to what Jeromy (441LSXTT) has in his 468
I don't know if his uses the same lobes, though.
#164
Talked myself into changing out my standard ATI dampner with a 10% underdriven version...just because LOL
#166
#167
Former Vendor
#169
I have a set of his heads on my 434ci solid roller with a single plane (very different than all of these other combinations). But if/when I ever dig into it again, I'm really interested in how well that top-end would fare on top of one of these short blocks! In my case it's generally not the intake that runs out of capability although I sure wish I could supply more plenum volume (that's a whole other story...).
Love following these big builds! Keep the great info (and pictures!) coming...
#170
I don't want to derail this great thread, but I would love a little commentary on this. I seem to recall that one of the early 468's posted here on CF used Tony's heads. As most know, Tony's LS7 heads use a relatively small intake port compared to just about every other LS7 head. On a 468, does that port start to run out of volume or is it capable of feeding all of those cubes sufficiently to 7500 rpm or so?
#171
Former Vendor
Both Jeremy and GSpeed are doing intake testing right now since there isn't much to pick from on intake manifolds to "fit" a Corvette as off the shelf units. You have a FAST, MSD, and High Ram for the most part. There are a ton of billet intakes but with the super short runners, don't fair well for power under the curve on a street car running 7000RPM and under. Being Louis and the gang at GSpeed are a shop and they are doing this on one of their house cars it is easier for them to do testing a bit quicker. The nice thing is that all of this will (and is) benefit everyone in far better performing HPR engines as a result. 700whp hyd roller, pump gas engines are not going to be un-heard of nor will they require super exotic parts and have to turn 8500 RPM.
#172
And at the end of the day, that is the truth... It really does depend on what you want the combo to do I suppose. It seems that most of these builds are running out of intake, so it's hard to know where the head limit will be until that can be solved. I suppose I was looking for more of a 'rule of thumb' on when an intake port would be too small to feed one of these engines, but that thinking is likely too limited in scope...
I continue to look forward to the learning you are doing, and more importantly, willing to share with the community. Thanx!
#173
It all depends. I know that sounds bad, but picking the right head, the right intake, and matching cam are all part of having a good build and performance in the RPM range you want it for. You wouldn't want to do a idle to 6000 RPM cam and pick a head to run 3000-7500, and a intake for 4500-9000. Picking a balanced combo for what the customer wants to do is the best way to go about it. You can kind of see this with the GSpeed Mule engine that was dynoing around 675 whp and Jeremy's more aggressive build (like Vic's here) and made 680ish whp but both were using the same MSD intake. The GSpeed engine was built around that intake in mind, where as these are going to be designed to take advantage of a bigger head and higher RPM intake manifold.
#174
Well, it's a no-go on the conicals......... no locators available for the LS heads at this time
So it's PAC 1209X's with titanium retainers matched to the titanium intake and Inconel exhaust valves.
Head assembly has commenced.
#175
Victor, are the Ti Intake valves from Victory Racing in NC (Katech's supplier and to most of NASCAR)?
Looking good!
Looking good!
#179
I run HPDE's, drag race on 1/4, 1/2, and soon 1 mile and further (over 2 miles in one event in Florida ).
The only thing I've never really gotten into was auto-x, though I've done it a few times when it was stock
#180
Former Vendor
Going to need a really good traction control setup if you are going to AutoX this and one heck of a tire.
