Stranded in my Z06 - Coolant Tee
Thanks for the link, just ordered one. These things have become a hot item.
BTW, CCP# 12955 is a Coca-Cola part no. Food & beverage grade lickable stainless steel.
Seems like I should have one in my tool box for future reference. Thanks OP.
thing knower
hmmm so my 2007 appears to have all three lines the same size.... and of course there appears to be a spot on the tee that looks like coolant crud. it's hard to see but there don't appear to be any hose clamps, ugh... any suggestions ?
thing knower
edit: apparently I don't have a tee there, I guess the 07 doesn't have one on that line... I can see from the pic that turbo posted there are two tee"s there
Look under the air box by the TB. The one your looking at is not the correct T
drewz06 (01-09-2019)
thing knower
so I wiggled the other line when I got to work and boom it exploded.... guess the tow company needs to figure how to get it out of the fourth floor parking garage now
#33
thing knower
its off to the dealer for a warranty repair, i was wanting to do a coolant flush prior to this, but looks like that will happen now
i didn't see the tee because its on the driver side of the car nearly directly under the intake...
damn plastic fittings, this exact same thing happened on my ford ranger about 6 months ago where the lines go to the heater core....
#37
yep! just glad i found it while parked, instead of cruising down the highway.....
#38
Good point - another plastic part in the cooling system, it could go bad just like the little t. Looks like the one in the picture may be trying to leak. Has anyone replaced it without replacing the whole hose assy?
#40
thing knower
so it turns out the other larger tee was about to snap as well.... i believe thats a molded 3 way hose but i can't find the gm part on any of the dealer sites....
its getting replaced today, ill get the part number for the larger 3 way hose and provide an update ( think its the heater core hose)
