[Z06] What motor mounts with MSD intake
It appears my stock motor mounts are starting to leak, I have an msd intake on there now that is pretty close to the cowl (1/8") and I did have to grind the firewall/install button head bolts on the back of the intake to get it to clear. So my question is if I'm ok now should I go with std height mounts from Hinson or Amt or elect to go with the 3/8 drop ones. I am a little concerned that the new mounts will be slightly taller than my 10 year old oem ones and could pose issues. I havent found much info on anyone running stock height mounts with an msd either.....
I just installed the 3/8 shorter Hinson mounts to my set up with a MSD. I did put a washer (spacer) to make them 1/4" shorter. Everything looks good as far as clearance all around.
Received 1,679 Likes
Stock....
Fabberge solid mounts on mine.
When you go to the shorter motor mounts do you have to go to shorter trans mounts as well? Another question. Im fairly new to this scene. You guys are only talking about replacing the bushing inswrt and not the metal mount that holds it as well ? Thanks
Also to add to this, the hinson mounts have been mentioned a few times that they are a touch taller than stock mounts. I would go with the 3/8 shorter, whether it be hinson, AMT, or whoever else.
I had initially ordered standard AMT mounts, but the MSD wouldn't fit. I swapped them for the 3/8 shorter ones, and used 2 washers to ensure the spring didn't hit the oil pan as well.
FYI - Having seen the Hinson and AMT in person, the AMT blow them away in appearance and perceived quality. Cannot speak for long term durability, but damn, the AMT's are beautifully machined pieces!
Sorry, I meant 1/4" shorter instead of 3/8" shorter. I figure it's better to get the shorter set because you can always add spacers to bring them up to OEM height if clearance is an issue.
Ended up ordering the 3/8" shorter AMT mounts. Nothing wrong with the Gibson's but I like the full metal design of the amt for heat reasons and the fact that there are no studs so install may be a little easier
Yea I was really thinking about ordering the taller ones however I'd rather be able to shim them if needed than have them be too tall and have issues. My MSD is VERY close to the cowl now with the stockers
I think running the shorter mount is good insurance with the slightly taller aftermarket intakes and its easy to increase height than try to remove with a stock height aftermarket mount as others have mentioned
-Tony
Did you notice any more NVH in the car running these mount compared to stock?
-Tony
-Tony
But the instant response of the engine to your right foot is very noticeable
There are some added vibrations transferred into the chassis. You feel a tingling in the seats at idle, and some of the plastic trim will buzz a little. But as soon as you get off idle, it is next to imperceptible.
I will be posting a thread soon with a discussion about this concerning some MSD customers experiencing the intake making contact at the rear of the manifold (not the top) and I will be modding the intakes I sell and port for customers in the future to help them avoid this nuisance issue after the fact.
I will post some pics as well.....while its a small percentage of customers that experience it, its still one of those items that if it can be avoided it is certainly a very welcomed situation to not have to deal with (or should I say have a much greater chance of not dealing with it).
Keep an eye out for that thread in a few days....Im waiting in a special shallow head bolt to arrive that I am also using in the problematic location to give even more clearance/protection against making contact.
Note ALL of what I just discussed is regarding the occasional rear contact point of the MSD against the firewall although the mounts that lower the engine some would help fix or improve that situation as well as the tight area under the cowl
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
