C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Advertisement
2009 c6 zo6 engine disaster. 72,000 miles
Old 01-15-2019, 09:22 AM
usctroj836
CF Senior Member
usctroj836's Avatar
Default 2009 c6 zo6 engine disaster. 72,000 miles
Need feedback please! Car is at Reliable Chevrolet Richardson Texas. Gmepp representative is on the way. I have the platinum plan. Zero deductible. According to the dealership a lifter(s) went bad and the cam is damaged. The car has been meticulously maintained. This is my third extended warranty. Absolutely no modifications. Never been tracked/raced. What am I looking at? What should I expect? Thank you forum.
usctroj836 is offline
Old 01-15-2019, 09:54 AM
Unreal
CF Senior Member
Unreal's Avatar
If it is under warranty with GMPP, you should basically expect a new motor, depending on the amount of damage. They need to see the extent of the cam damage and how much metal it spit into the motor.
A fairly common failure on LS motors.
Unreal is online now
Old 01-15-2019, 10:32 AM
0H8Z06
CF Senior Member
0H8Z06's Avatar
I too am in Dallas and am familiar with Reliable. Not for the reasons you are.
I am with Unreal... You should demand a complete Long block. The likely culprit was the cam itself w the soft lobes which in turn caused the lifter(s) to fail. It is pretty common. Do not be passive on this. Reliable is going to attempt to nickel and dime you, kinda like an insurance company when they are negotiating.
Depending on how Warranty reads YOU are in the drivers seat. If need be have a 3rd party go in and explain the whole soft lobe thing.
The ONLY ding that I can see is the mileage. Tell them you want to see the cam lobes and failed lifters. It will certainly tell the story.
Just my .02
0H8Z06 is offline
Old 01-15-2019, 11:27 AM
leadfart
CF Senior Member
leadfart's Avatar
New engine, be prepared to fight. GMEPP will try to deny, if they can. Good luck!
leadfart is offline
Old 01-15-2019, 12:18 PM
Corvette_D
CF Senior Member
Did they actually open up the engine to determine that? When my engine blew, the dealership did basically 0 to diagnose it properly. This led to a 100% wrong diagnosis. You should ask them if they tore down the car properly, and I don't mean just popping the hood and looking in.
Corvette_D is offline
Old 01-15-2019, 12:21 PM
PureJoy
CF Senior Member
PureJoy's Avatar
Make sure you tell them you used the recommended oil!!! Seriously!!!
PureJoy is offline
Old 01-15-2019, 12:26 PM
usctroj836
CF Senior Member
usctroj836's Avatar
Oil changes done at reliable with mobile 1 5 w 30. Also just signed the platinum warranty at 70001miles. Had to wait 1000 miles and 1 month for the warranty to be active. This happened at 72,025. Everybody knew what was going on. The cost was about 5,400 for 36 months or 24,000 miles. Not cheap.
Old 01-15-2019, 12:29 PM
usctroj836
CF Senior Member
usctroj836's Avatar
I only received a phone call from the service advisor stating this is the tech’s diagnosis and that a GMEPP inspector will be there in 48 hours and that he (the advisor) will call me back.
Old 01-15-2019, 12:30 PM
Jaybird29
CF Senior Member
Jaybird29's Avatar
Also request new oil lines and dry sump to be removed and cleaned.
Jaybird29 is offline
Old 01-15-2019, 01:33 PM
MTPZ06
CF Senior Member
Support Corvetteforum!
MTPZ06's Avatar
Fairly common if the diagnosis is correct...probably the second most common failure after the excessive guide wear issues. You'll most likely require a new engine if the damage is extensive enough; which will also require new oil cooler and lines, and I would push for new sump and lines...but as mentioned above, the sump itself can be disassembled and cleaned.
MTPZ06 is offline
Old 01-15-2019, 01:45 PM
Unreal
CF Senior Member
Unreal's Avatar
Dealer shouldn't fight you, as it is just money in their pocket. If anything they should be on your side trying to milk as much money out of GMPP as possible.
Cam/lifter failure and rod failure are definately battling it out for the #2 most common failure to take these motors out after guides/valves.
Old 01-15-2019, 01:52 PM
keeso6z
CF Senior Member
Good thing you got the extended warranty. But it would have been cheaper to fix the valves/heads. Staying with the original heads/valves with that mileage is a big risk. But now it looks like a new engine for the car, which will have a lot less miles on it.
keeso6z is offline
Old 01-15-2019, 05:01 PM
freddyvette
CF Senior Member
A new block for me turned out to be around $14500
freddyvette is offline
Old 01-15-2019, 06:41 PM
usctroj836
CF Senior Member
usctroj836's Avatar
Adjuster came by and heard the noise inside the engine. Asked for it to be torn down so the exact point of failure can be found. Reliable called me and asked for permission to proceed. Reliable said this is standard operating procedure. I said yes tear it down.
Old 01-15-2019, 07:03 PM
fake
CF Senior Member
Once again it happens and GM tries to wiggle out! If you loose go to your state DMV and let them know your situation and let this forum no your out come. If you think GM have problems now you should have been buying there **** in 89 i had two Chevrolets fail and i ate the repairs.
fake is online now
Old 01-15-2019, 07:05 PM
Dirty Howie
CF Senior Member
Dirty Howie's Avatar
You have a warranty .............. stop worrying. You have likely paid for and desrve a new motor with all the warranty premiums you have paid !!!
Get some pictures for us.
DH
Dirty Howie is offline
Old 01-15-2019, 09:33 PM
Dan_the_C5_Man
CF Senior Member
Dan_the_C5_Man's Avatar
This failure mode has nothing to do with "the valve guide / head fix" topic.
The OP's biggest challenge at this point is if they push to just replace the cam and failed lifter(s) and nothing more, along with the standard stealership crappy service depertment behavior like cracking the fenders, greasing up the interior, forgetting to refill the trans if they replace the engine, not replacing or properly cleaning the tank and lines, etc.
Dan_the_C5_Man is offline
Old 01-15-2019, 10:50 PM
usctroj836
CF Senior Member
usctroj836's Avatar
If the GMEPP people are smart they will replace the motor. If they just fix the broken parts there is still 2 years and 10 months left on the warranty so they can get hit again. A new motor I believe comes with a 3 year 36k mile warranty. They would not have to worry about any future big hits. That is what I would do. You get what you pay for.
Old 01-15-2019, 11:24 PM
freddyvette
CF Senior Member
OEM LS7 motors are garbage to begin with, and they know this because they have an enormous warranty claim database to refer from. But at least you'll have a good base to start from.
Old 01-16-2019, 01:39 AM
Corvette_D
CF Senior Member
Once again another dealer basically popping the hood and guessing what's wrong. Glad that you said yes to tear it down! You'll likely get an engine.
Quick Reply: 2009 c6 zo6 engine disaster. 72,000 miles
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
