E85 setups for 600+ C6Z
What setups for E85 are you all are running on cars with higher compression (12.5+) that will easily support more than 600whp? I’ve searched the topic and gotten hugely different answers. Wanting to know what pumps, injectors, lines, and style system (return vs returnless).
What Jay said. No reason to touch lines, return, rails, etc etc. Throw a 450/485/520 Walbro, and some ID 850/1050x and be done.
Received 1,679 Likes
I'll be doing this soon... Going with a Flex set up so I can run both E85/93 pump...
Not a question of "if" but "when" that stock pump goes.
Where do you typically get your E85 in Dallas..? I know its everywhere.. Just trying to figure out the best places. I hear Kroger has good E85...
I live in north Fort Worth and next to a Racetrack that has E85, but the E is 69%. I hear Kroger has the best E85, but never tried it. Next closest to me is over in Southlake.
TXGS507 (01-22-2019)
I run the stock pump with e85 and Id1050x st 550whp going on 10k miles and 2 years. I do run 93 through it every few months but so far no issues
Heads and cam z06 made 10whp more than I did right after me.....and I'm neck and neck with a buddies btr stg 3 c6z so id say not. you're also missign a few mods. Not sure what an IW clutch is either
Stock fuel pump
85lb injectors
BAP (Boost-a-Pump)
Flex Fuel Sensor
Stock fuel pump has been holding for over 2 years. I run a tank of 93 occasionally, but mostly E85 from Kroger over here near Garland. I can definitely tell a HP increase from 93 to the E85.
Pete
85lb injectors
BAP (Boost-a-Pump)
Flex Fuel Sensor
Pete
