[Z06] Air Intake Parts Question
I got a 2011 Z06 in time for it to hibernate so I figured I would do some preventative maintenance and other small projects (thanks for DIY threads on clutch fluid, battery tender external quick disconnect, on-star delete, etc). The car came with an aftermarket intake but the previous owner also had the original. So I got a new filter and I am trying to install the original intake. The only issue is that the original intake did not come with the small parts. I was able to order the parts that attach it to the radiator cover (2 and 3 below, 25099299 and 25099300).
Unfortunately there are also two screw holes in the back of the bumper that supported the aftermaket intake. I am not sure what is supposed to go in those screw holes and I am unable to find the associated parts diagram (red circles around mystery screw holes below).
Does anyone know what goes in these holes? Can anyone point me in the direction of the correct parts diagram or help with part numbers?
Also, I'll be trying to sell this Blackwing intake soon - do I have much of a chance at selling it locally? will it fit on all C6s or just Z06s?
they may be the holes for the air bridge to attach to the support. i no longer have my original intake, I'm using a Halltech mf103 with the beehive shroud. fit the original intake and see what lines up with the holes.
Thanks for the reply - there is no feature on the air bridge that would suggest something needs to be there. However I have been searching online and seen what appears to be some small studs, though I am not sure it's for an LS7.
I just looked to be sure. Whatever is on your car has been added. In stock form there is nothing there but 2 empty holes. No threads or anything. I would've snapped a pic but I couldn't pull my halltech beehive up enough for the camera to focus without yanking the push pins out
