600whp z06
Michelin 4S - surprisingly great in the rain as well. Also I want to clear this up...its tq that spins tires not hp and usually higher rpm n/a engines have less tq down low which stops them from lighting up off the line vs cars with stock cam low rpm tree tugging torque. I feel better now.
My experience in 500-550whp:
DR's hook really well, as they should, impacts but does not kill handling. They feel slightly balloony through harder turns but not bad. Damp road = extreme caution and any water on the road at all = stop and wait for it to dry. This was on brand-new ET Streets, modest rain, 80F.
The around-200TW tires hook pretty hard and can handle rain reasonably well. Advan Neova, R888, etc. They handle awesome.
200+TW tires are fine from a roll. You can blow the tires off in 1-2 for sure, maybe in 3rd depending on gearing, power level & surface. My car at 550whp with 4.1 gears, traction in 3rd is surface dependent.
Personally I enjoy managing traction, and hate having to worry about a sprinkle of water, so I run 200-300TW tires.
Personal choice. I would not pass up a 'perfect' 600+ car due to tire choice
01RedZ (02-18-2019)
This is a safety trade-off in both categories, spinning your tires on dry pavement is also dangerous during hard acceleration. What you should focus on is finding what works for you.
In my case I look to create ideal situations with tires, I replace my tires before tread depths get too low. this is directly related to hydroplaning resistance. When you combine the tires we use with the sizes we use, it's just a terrible combination for water evacuation.
You will always read stories about corvettes hydroplaning, nature of the beast. Your best fighting chance is with an all season tire if this is where your priorities are.
So outside of being able to punch it from a Dig has moving back to regular tire really decreased your enjoyment of driving the car?
My dad has a 14 1LE Camaro with Procharger, cam & full exhaust that dynos 725RWHP. He is on goodyear eagle RSAs and you can hammer it in second from a roll and it doesn't miss a beat. From what i have read it sounds like the LS7 will blow a PSS tire off at almost any speed through 3rd?
I'm 600 at the tire so I know what you are talking about...just know when you can floor it and when not to. Id rather have a car that can break traction on demand in 1st vs a car that is to pu$$y to be able to lol
what rear suspension mods and are these factory size tires(20’s) on this Camaro? I understand it’s significantly heavier in the rear compared to a ZO6, but I also find it very hard to believe a stock suspension and an all weather street tire could ever hold 725whp from 2nd, probably not even third. Could be wrong, been wrong before but this seems hard to believe that tire on a 20 inch wheel would hold factory power levels not to mention 725whp. I did meet a guy this weekend with basically the same numbers on a 2015 Camaro with a D1SC.....he had 17x11 welds and Mickey et streets I believe they were 305/45/17 could have been 50’s though point being he had a very large amount of side wall.
Open road 55 MPH in 2nd hammered it and it stuck all the way to redline. Sidestep the clutch in first and its a smoke show. You also could no launch the car on them but they performed rather well that day. It was 80+ degrees out that day and humid so peak HP numbers were likely down as well. Tires were also relatively new. He has commented to me on multiple occasions that without heat in them they are pretty useless.
No rear suspension mods. The car is a 1le so better suspension from the factory but not setup for that kind of power.
I know how crazy my original statement sounds but that was my experience in the car. Open road 55 MPH in 2nd hammered it and it stuck all the way to redline. Sidestep the clutch in first and its a smoke show. You also could no launch the car on them but they performed rather well that day. It was 80+ degrees out that day and humid so peak HP numbers were likely down as well. Tires were also relatively new. He has commented to me on multiple occasions that without heat in them they are pretty useless.
And if traction control is on, and cutting in, hard to compare that as well.
My 06 C6 Vert makes 606 RWHP w/516 torque but the nannies, both traction control and active handling must be disabled since they were set up from the factory when stock.
I suppose there is no way to have the nannies tuned back in is there?
Maybe try the MPSS in 345 if you still have the stock 19 inch wheel. Another option is the R888 series for street tires.
It didn’t decrease my enjoyment of the car because I didn’t have to worry about dying driving the car in the rain. This is based solely on my personal experience. I’m not a stranger to high HP cars or cars with DR’s. I had just one really bad experience with DR’s which sticks. Some have gone years w/out an issue with DR’s I am just not one of them.
01RedZ (02-19-2019)
#33
I want to enjoy my car without stressing about a shower. I've come to enjoy managing traction with the loud pedal at lower speeds around town. Some of the onlookers do too
01RedZ (02-19-2019)
#34
lol now that makes sense!
More or less the same here. The DRs were just too sketchy in the wet, I managed to keep it straight but that rear end was very, shall we say, 'non-secure'! I could keep it going at 25mph but that's a major hazard when traffic is doing 70...
#35
Not typically. Unfortunately it's a catch 22 - go with a stickier DR and forget about driving in the rain or stick with a PS4S and deal with wheel spin. Really comes down to how you use the car and what you prioritize. Could always have a set for both occasions...
#36
#37
R888s are not that much better than a drag radial. Still a dry weather competition tire.
Have two sets of wheels is the answer.
#38
Thanks to all that contributed to this discussion.
It helped me decide to go ahead and order Michelin Pilot Sport A/S 3+ Run Flats today and think about getting a separate set of tires and wheels for hot sunny days that I will not be out of town and have to risk dealing rain.
The peace of mind Run Flats will give when we do take an out of town trip will be worth have two set of tires and wheels. Thanks again!
