C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] LPE snout clearance question
Old 02-20-2019, 03:37 AM
03Cobrra
03Cobrra's Avatar
Default LPE snout clearance question
I’m looking to run a little more boost, current setup is a 2.6 upper on an lpe snout and IW 10% lower. Don’t really want to deal with swapping lower pulleys right now, I would like to go to as small as possible on the upper but was wondering if the Lpe snout needs to be machined or clearanced at all and if so at what size pulley. Thanks in advance.
Old 02-20-2019, 01:06 PM
Bigjsn250
Bigjsn250's Avatar
It does not, I run a 2.20 upper and 10% IW lower on my car, great set up.
Old 02-21-2019, 10:06 AM
03Cobrra
03Cobrra's Avatar
Awesome to hear that, thanks. How much boost do you see with that setup? Also what size belt are you running?
Old 02-21-2019, 11:38 AM
Action75
Action75's Avatar
Use this chart...
Old 02-21-2019, 02:01 PM
Bigjsn250
Bigjsn250's Avatar
I use a stock size belt with a 76mm idler on the drivers side. I have a Synergy Intake, 102mm TB, Kong race ported LPE snout, Kong race ported blower, untouched heads, a BTR Stage 3 cam and 2" headers and see between 17-18lbs.
Old 02-21-2019, 02:51 PM
I brake for nothing
I brake for nothing's Avatar
What kind of power does that put down ? Do you have a build thread you can link to ?
Old 02-22-2019, 11:58 AM
03Cobrra
03Cobrra's Avatar
Thanks for the info. Funny enough that is exactly the same setup I have. What kind of numbers did you make if you don’t mind?
Old 02-23-2019, 12:54 AM
Bigjsn250
Bigjsn250's Avatar
Just shy of 800whp on e85.
Old 02-23-2019, 12:21 PM
chassed
chassed's Avatar
im starting to think the stock cam is a better option.
Old 02-24-2019, 09:47 PM
03Cobrra
03Cobrra's Avatar
Awesome, not bad.
Why is that? I know there are better options than the BTR 3 these days but it can’t be that bad.
To LPE snout clearance question
Quick Reply: [ZR1] LPE snout clearance question
