C6 Corvette ZR1 & Z06 General info about GMs Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Advertisement
2007 Z06 - 100K Mile Tune Tips
Old 02-25-2019, 01:24 PM
Troika
Junior Member
Liked 0 Times in 0 Posts
Default 2007 Z06 - 100K Mile Tune Tips
I've got a 2007 Z06 that is about to turn the century mark at 100K miles. I have always done all of my maintenance and the car has been a dream to own in terms of reliability. From a performance perspective I would say she runs as strong now as she did from day one over 11 years ago. I was curious if anyone had any suggestions for tune up or replacement items, other than the GM recommended. I'm in the middle of sinking $50K into a 69' Camaro build at the moment so I'm only looking at stock service / replacement tips for now. Specifically interested if there are any suggestions relative to injector service or replacement.
Troika is offline
Old 02-25-2019, 01:30 PM
MTPZ06
CF Senior Member
Support Corvetteforum!
MTPZ06's Avatar
Liked 1,169 Times in 1,036 Posts
Valve job.
MTPZ06 is online now
The following users liked this post: MTPZ06
Troika (02-25-2019)
Old 02-25-2019, 01:49 PM
Troika
Junior Member
Thanks for the feedback however it's kinda hard for me to justify the money to "break the seal" on the top end without going deeper (not that I wouldn't enjoy it). That said, I know the LS7's history and you are right, probably worth spending the time / money.
Troika is offline
Old 02-25-2019, 01:59 PM
JerriVette
CF Senior Member
JerriVette's Avatar
Liked 991 Times in 684 Posts
Just change the wires and plugs and whatever fluids you feel like doing.
one owner ls3 c6 z51 now at 130k.
these cars are built extremely well.
just regular maintaince and add gas,
enjoy
JerriVette is online now
The following users liked this post: JerriVette
Troika (02-25-2019)
MTPZ06
CF Senior Member
MTPZ06's Avatar
I'd say its money well spent...especially if you do your own wrenching. Couple grand to save a motor that costs 5 figures, and keep it on the road for another 100K. Refresh of all fluids is in order, and since you asked about injectors...Injector Repair LLC can do ultrasonic cleaning and flow testing for $17/injector.
Troika (02-25-2019)
Old 02-25-2019, 06:35 PM
Troika
Junior Member
Thank you, I did the plugs at about the 75K range but the wires are a good suggestion,
Troika is offline
Old 02-25-2019, 06:42 PM
Troika
Junior Member
Thanks again. That's a hot tip on the ultrasonic testing, I was just reading an article about that. I've kept all the fluids fresh through the years on my own schedule which exceeds GM's recommended intervals by a bit.
Troika is offline
Old 02-25-2019, 06:47 PM
TOM WELCH
CF Senior Member
Liked 16 Times in 14 Posts
BG44K and BG EPR, are two products that we use and recommend. 44K every 4-5 fillups, EPR every 4-5 oil changes, these are not snake oil, they are proven products, I use them in my own vehicles and sell them at my shop.
TOM WELCH is offline
The following users liked this post: TOM WELCH
Troika (02-25-2019)
Old 02-25-2019, 11:33 PM
Hib Halverson
CF Senior Member
Liked 146 Times in 94 Posts
At 100K and assuming no service work other than oil and spark plug changes have been done...
Flush the brakes
Change the rear axle lube.
Change the trans lube
Change the power streering fluid.
Replace the drive belts
Replace the plug wires
Replace the clutch disc
Do a four wheel alignment
Replace the cabin air filter
Pull the injectors and have them cleaned
Hib Halverson is offline
The following users liked this post: Hib Halverson
Troika (02-26-2019)
Old 02-26-2019, 07:04 AM
Troika
Junior Member
Flush the brakes
Thanks, I've kept all the driveline fluids you've mentioned fresh through the years. Clutch disc is also fairly fresh since a run down Pikes Peak a while back forced me to replace (long story). Tires and wheels are new. You are the second to suggest the injector service and I think tha't's a great idea, making plans to tackle that next week. All in all, from the suggestions I've received, I think we are in pretty good shape. I'll do injectors, plug wires and the alignment.
I appreciate the feedback from those that have taken the time to comment. Possibly one of the more boring tech questions however it's always good to hear from others because there's usually something obvious that we overlook.
Troika is offline
Old 02-26-2019, 07:15 PM
MAD Matt
CF Senior Member
Liked 48 Times in 39 Posts
Does your car have the stock heads as delivered? The reason I ask is because some cars have experienced valve guide issues as we all know. It would be comforting to hear from folks that have stock, untouched heads and higher mileage. Just curious and congrats on making it to 100K without any major issues...good to know.
MAD Matt is offline
Old 02-26-2019, 07:27 PM
bjmsam
CF Senior Member
bjmsam's Avatar
Liked 35 Times in 30 Posts
I appreciate the sensible request and helpful responses. My 2007 Z06 currently has ~82k miles with only regular maintenance (plus a thorough valve-to-guide clearance "wiggle test" at 62k miles for peace of mind). I will follow your lead as it approaches 100k miles and hopefully see another 100k without becoming a statistic in the mileage before LS7 engine failure stock thread.
Meanwhile, your last post piqued my interest about losing a clutch while descending Pike's Peak. What happened?
bjmsam is offline
Old 02-27-2019, 09:11 AM
Troika
Junior Member
Yes my car has remained stock despite the temptation many times to pull the trigger on various modifications (recent change in wheels excluded). In my opinion, the C6 Z06 was a machine well ahead of it's time and I feel GM engineering hit one out of the park in terms of how the car performs. From the daily driver perspective, I think a guy can spend a lot of money chasing aftermarket products that may only marginally improve / change the performance of a machine that really didn't need changing. Don't get me wrong, while I don't track this car, I do drive it hard and demand that it performs at a high level, the way it was meant to be. That said, I'm also not afraid to throw the wife in it and take off on a two week / 3000 mile adventure which we have done numerous times.
I'm aware of the valve guide issue and I guess all I can say is, as I pass the 100K mile mark, I'll keep my fingers crossed.
Troika is offline
Old 02-27-2019, 09:21 AM
Troika
Junior Member
The PIkes Peak run was a bit of an oddity. We did a "non-sanctioned" descent from the peak down to Colorado Springs and when we got down I had an issue with the clutch slave cylinder that caused the disc to take a little abuse. The slave cylinder stopped working completely before we got very far so we went to the local Chevy dealer and had it replaced (we were in the middle of a road trip that originated in Houston). The mechanic said that the seals in the slave cylinder failed because they were dry....from not being driven. At the time I was working overseas for extended periods and the car was sitting for extended periods without being driven. I'll file this one in the self inflicted category.
Troika is offline
Old 02-27-2019, 09:23 AM
Troika
Junior Member
Yes my car still have the original heads.
Troika is offline
Old 03-05-2019, 10:14 AM
minavizz
CF Member
minavizz's Avatar
Liked 5 Times in 5 Posts
Dang, that 69 camaro build tho!
I have a 68 Camaro you could have for $35 instead
minavizz is offline
Quick Reply: 2007 Z06 - 100K Mile Tune Tips
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
