[ZR1] ZR1 ultimate Track build getting closer to finished
My C6 ZR1 modifications list - goal is full time track racer/TT car that can go around COTA at 2:10 or so
Speed bleeders on all calipers
Pagid RSC1 pads all around
SS brake lines
Pfadt camber kit
Pfadt HD sway bars front and rear
LG Rear tow hook
PFADT Front tow hook
GS1R 18” wheels with R7’s mounted
Front bump steer kit
Rear bump steer kit
ARP wheel studs with gorilla lug nuts
Tunnel heat shield
2”x3” kooks headers
Kooks cat-less x-pipe
Sparco Egro seats
6 point harnesses
Shark bar harnesses bar (remove when roll-bar arrives)
RPM roll-bar 6 point with rear hoop
Solo 2 DL w/ smartycam GP
QA1 vansteel DA coilovers 800/750
Pfadt spherical bushings
Moog ball joints x8
Billet pedal covers
SS brake lines
ARP wheel studs with gorilla nuts
DSX Flex fuel sensor - car to run on E85
K&N cold air intake
iD1050 injectors
Prospeed Reinforced bricks
ZERO deg thermostat (removed internals)
Ron Davis radiator (big AF)
Edelbrock heat exchanger (modified with 1” inlet/outlet)
Prospeed billet 3/4” inlets
Kong divider
10 gal rear mount ice/water tank
AFCO C7 exchanger (modified 1” inlet/outlet) - rear mounted
All 1” lines on exchanger system except just before bricks
Reprogrammed EMP pump 24 amp 4500 rpm
Meth/water injection w/ 7 gal rear tank (100% water to be injected)
Auto-blip rev matching
Hinson short throw shifter
DEI TI wrapping on headers and X-pipe
Castrol SRF brake fluid
Elite engineering Dual catch can system
Replaced polycarbonate vent window with function louvered vent
Dual vent inserts on hood also
Custom made front splitter 5” out from stock carbon fiber splitter
Custom front brake cooling system
APR GT-1000 wing bumper mounted
DC power 270 amp alternator for ZR1
Will play with blower pulley sizes upon successful AIT temp reduction mods from above - maybe go 15-17 PSI vs stock 10 PSI. Initial AIT’s with stock pulleys should not get above 110-120F after full 20 minute session (at least that’s plan). With have essentially 4x the heat exchanger area as stock with 2X flow and 10x system volume.
First pass engine/cooling mods should put 625-650 HP to ground - need closer to 800 rwHp to go 2:10 lap at COTA....
All sorts of videos of everything done so far in car in my channel - remaining upgrades and more track time videos coming.....
SS brake lines
Pfadt camber kit
LG Rear tow hook
Rear bump steer kit
Tunnel heat shield
2”x3” kooks headers
Sparco Egro seats
6 point harnesses
Moog ball joints x8
Billet pedal covers
SS brake lines
K&N cold air intake
iD1050 injectors
Kong divider
Cool project.
Can you share what Prospeed charges to put the 1" inlets on the Edelbrock heat exchanger ?
Also have you considered selling off the ZR1 hood and getting an aftermarket extractor hood. The ZR1 hood is worth quite a bit as I understand it.
A7 instead of R7 if you are chasing time. Swap to C6Z brakes or AP Racing as your CCB's are worth a ton and steel would be cheaper to swap for track days.
Prospeed fabrication rate is $125 per hour - took less than 30 minutes to put the 1” on the Edelbrock exchanger.
yes, A7’s later after car all settled out - R7’s to get some track miles in to set everything up.
tried to sell Hood for $4000 - no takers. Going to replaced plexiglass with louvred insert and add side vents just behind radiator - yes going to dremmel a couple openings.....
also tried to sell brakes before - no takers.....looked at AP racing brakes already - rotors will have about same life as stock and are $450 to replace vs. $1100 for CC rotors. Plus there’s a weight savings with the CC’s.
just wrapping plumbing routing for rear tank, rear pump to front and back - will post up video of how it all came together - changed a few things but not much...
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Great build OP, sounds like you have matters well under control. Looking forward to your results and thanks much for posting! Always love to see a C6 on the track, especially a built C6ZR1! I'm not sure where you are located but if you are anywhere in the Northeast we should hook-up. I am at pretty much every track (WGI, NJMP, Limerock etc) all season long either racing or instructing and would love to see your car. Either way, fantastic build with much attention to detail - and thanks for the vids! Subscribed.
The rotors are not steel. They are iron. And the hat is billet aluminum. And the calipers are forged aluminum. There is no steel in the construction (except for minor bits like through-bolts, pistons and lines), nor should there be. They are referred to as an "iron brake" setup - not a steel one. And going to C6Z brakes would be a significant downgrade. And he should only move to A7 when he is actually racing or qualifying as they heat cycle out very, very rapidly (I know this because I use all of these tires on my C6Z, not because I read about it). For testing, HPDE and most 30 minute sprint racing the R7 is superior as it is almost as grippy as A7 yet takes many more heat cycles and is easier to manage tire temps. I only put on the A7s when I need to set my fastest time and I only have a few laps to do it (as they come up to temp VERY quickly and are super grippy before they fall off).
Located in Houston but might head up to Mid-Ohio for NASA nats - if I am ready....working on second car that will be a STU monster....the ZR1 is trainer car....lol
2nd car get built out in AZ by a former NASA national champ who now builds cars for living - car will be close to 2 lbs per wHP......I pick his brain all the time on the ZR1....
from first session at COTA in car back in August - brakes were more than adequate - needed good fluid purge and some better cooling up front - all of which is on the mod list. Engine got hot AF - 260+ coolant and close to 285 oil temp - needless to say backed off at that point - so main focus has been getting temps down. Will see how the Ron Davis radiator does - it should have close to 60% more cooling capacity than stock - and will help all around.
the LS9 heat exchanger system as it comes from factory is a joke - its just not made for sustained hard driving. AIT2 and coolant pulled timing.....will need more HP to get lap times down and raising boost easiest way to get there - provided AIT under control
taking my time to do ZR1 right and if something doesn’t look or feel right - it generally gets changed...
Buddy of mine has a TIKT system on his 850 rwhp Vengeance built ZR1. From what I have heard he has no cooling issues on track. I think he was at Sebring a couple of months ago.
I will likely be at Mid-Ohio for Nationals. Hope to see you there.
Other car is a FFR Coupe-R with a 5.2 XS FPP crate motor with twin turbos running on E85 - will easily put 1200+ Hp to the ground. There’s build thread over at FFR forum with all the details (yes, it’s basically a Ford....) gettting AP racing brakes, Penske shocks etc etc etc
For the ZR1 - venting the hood in three places and have sealed up around radiator inlet to force all the cool air through vs. going elsewhere.
take heat management pretty seriously - check out the OCD level in the exhaust...…
First time there was a Chin track day - crowded...actual best lap was 2:32 in lot’s of traffic. Put a composite lap together from data - best times in several segments - was 2:25 piecing that together. Hit 165 mph on the back straight several times...The ZR1 got hot AF after about 2 hard laps so eased up a bunch to let it cool down. Spent lot’s of time at Bahrain GP and Yas Marina while working over seas for last 5 years......
Anything sub 2:20 is rolling pretty good. Mid teens for a car that is in the hands of an amateur is really ripping and the fastest are typically low teens. Once you get into the sub 2:10 range you're in GTLM territory with times anywhere from 2:04's to 2:10's depending on the car and driver.
Like all cars that are truly fast power alone doesn't make them that way as is shown by the GTLM cars. Chassis development plays a huge part.
Good luck with your build and your quest!! Have fun along the way!!
https://youtu.be/976pb7woxDk
My ZR1 is fast at Yas Marina. On Forza 7. Lol, I know that had to of been a blast though.
2020 Corvette of the Year Finalist (track prepared)
C7 of Year Winner (track prepared) 2019
Not sure if Feras posts here but him and his prepped C6 Z06 just won super lap battle in his class with street tires at 2:18.588
A well prepped ZR1 with A7's I would very much like to see run at COTA.
Is there not pictures of OP's car in this thread?
