C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Carbon Fiber top
Old 02-27-2019, 02:00 AM
Wm.Hacker
Wm.Hacker's Avatar
Default Carbon Fiber top
Have a question guys, seems like I have read somewhere the CF tops on the Zr1 are bad about squeaking which mine does when I hit a good bump. Anybody had this issue and are there any remedies?
Old 02-27-2019, 12:34 PM
Werks
Werks's Avatar
Unlike on the standard C6 as you know on the Z06 & ZR1 the top is permanently attached (it's bolted on). Double check to make sure that the bolts holding the top on are tight because if they loosen up a little when you hit a good sized bump the chassis will flex slighly making the top moves a bit and you will get the squeeking that you are describing. Noticed the same with my track car too and ultimately after digging into things that's what the cause of it was.
Old 02-27-2019, 05:18 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,143 Likes on 597 Posts
How do you get at those bolts?
Pull the headliner?
Old 02-28-2019, 08:32 AM
Apocolipse
Apocolipse's Avatar
Received 1,282 Likes on 927 Posts
Yes - pull the rear cover and slide the headliner back and out the trunk. They say not to reuse bolts but I think tjat is because they have loctite on them from factory. I do not believe they are TTY bolts.
Old 02-28-2019, 05:14 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
"...pull the rear cover..."
Are you talking about the rear cargo shade or the hard trim on the underside of the halo bar?
Old 02-28-2019, 05:24 PM
Apocolipse
Apocolipse's Avatar
Apologies - the cover that is directly under the halo.
Old 03-01-2019, 01:19 PM
Werks
Werks's Avatar
Old 03-01-2019, 05:17 PM
ZRCLONE
ZRCLONE's Avatar
Obviously it is defective, I will gladly take it off your hands.
To Carbon Fiber top
Quick Reply: [ZR1] Carbon Fiber top
