[Z06] I prefilled the oil filter then added 8qts, Did I overfill?
2006 C6Z so capacity is 8qts. Should I drain some oil out or do you think the prefilled oil filter amount is insignificant?
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
How would we know? Why not warm the car up and look at the dipstick? An extra half quart will not cause issues, but it is hard to understand why you wouldn't just look at the dipstick. And you will never get all of the oil out of the system when changing the oil, as oil stays in the motor, oil galleries and lines. So you fill, warm car up and then check.
pdc001 (03-06-2019)
I put 7 quarts in mine plus some in the filter and then checked and added. If the level when warm is between to the two marks you are fine. If over the top market, drain some out.
2k Cobra (03-06-2019)
Former Vendor
As best practice, next time, pour in a quart less, then allow oil to warm and check level - you can add little by little until you reach correct level. You're not going to hurt anything at idle unless you are way pass the filled line which will cause oil to spit all over the place.
Hope this helps.
Thanks.
Carlos
Thanks Carlos, I plan to start it and do an idle warm up (not ideal, I prefer to drive slowly for a warm up), shut down and check level at 7 minutes then if it’s high, I have fluid vacuum pump (like the ones used for bleeding brakes but with a large tank reservoir) and I plan to use a new vinyl tube attached to the pump and insert it into the fill of the dry sump tank and suck out oil until the level is at the top mark.
Former Vendor
I hear ya on the warm up dealio, but would hate to see you over pressurized matters by driving it - even if at low R's. Idle is just Idle not as much pressure vs loading the engine. On the flip side, you have a relatively pain free of abstracting oil from the sump - then just remove some (1/2 quart) and drive it, then check it. You can always add some back in.
Let us know how you make out.
Thanks,
Carlos
I let it idle till the oil temp hit 160 and then shut it down and waited eight minutes. The oil was about an eighth of an inch above the full line/hole. I used the fluid vac to suck out a small amount of fluid from the tank and then it registered about a 16th of an inch below the full mark. Going to drive it once the rain stops and will check it again.
