[Z06] Injectors needed for E85 N/A Build? ~600whp
Hi all,
Just purchased my first vette a few months ago and...well...things have snowballed. I initially have heard about valve guide issues, so I decided to send my heads off to get CNC/Ported and rebuilt, then decided to mill some off for free horsepower. Then I decided I might as well do the cam while its off, stage 3. Then I came across a good deal on some Kooks headers & xpipe ($1000), then I came across a good deal on a MSD Intake Manifold ($725). Well now I'm trying to get everything matched up well before the tune so I don't have to do things twice.
I live in Tampa, FL and will be trying to have Jeremy at Fasterproms do the tune. I have already ordered the DSX E85 kit and was wondering what I need to do with injectors. I don't plan on modifying the engine must past where it is, no forced induction, want to keep it N/A. Can someone point me in the right direction of where stock injector limits are and where I should be safely? How will the stock fuel pump stand up to this? I think I kinda jumped the gun here, looking for a nudge in the right direction. Thanks in advance!
Trey
EDIT: I'm assuming high 500's with this build, but want to be able to have injectors for 600whp+ - reason for numbers in title. Before I get flamed.
Former Vendor
Hi all,
Trey
I will tell you right now, ditch those stock injectors and get yourself a set of FAST 85lbs units. We sell them, but you can also get them from any other authorized retailer. If your pump is up to the task, then leave it alone until if and/or when it gets fatigued. If your budget allows, get yourself a 450lph Walboro in-tank fuel pump.
You can check condition of pump buy plugging in a mechanical gauge on the rail valve (driver side). FUEL PSI should read 60psi and stay there as you drive (RPM climbs). You can do a quick and dirty check by connecting the mechanical gauge with a long line, run gauge to your windshield, tape it facing driver seat and take a quick spin. Monitor psi and if it stays at 60psi (do not drop) and then you're good, If not, then you will need to address the pump. Larger injectors will not save you from a mechanical mess if your pump is tired.
Follow me?
Let me know if I can be of any further assistance.
Thanks,
Carlos
I'm not sure hes going to properly be able to tell during a top-speed pull to 150~mph if the fuel pressure is dropped 5 to 10psi or whatever on a gauge taped to the windshield.
The pump could flow fine for quick bursts (1st and 2nd) but be miserably out of juice during longer pulls.
Former Vendor
Thanks,
Carlos
I have 850's, 750's would suffice.
Congrats Trey.
Follow me?
Thanks,
Carlos
Follow me?
Thanks,
Carlos
Thanks for the input. So the consensus is the stockers will not be OK to run full E85 at that power level?
Round 3 will include E and a Hi-Ram so I have a ton of room to play with.
TreyE (03-06-2019)
Former Vendor
And yes, stock injectors are no bueno to run with E85 - they do not flow enough.
Thanks,
Carlos
