427 heads cam
427 heads cam
I recently sent my heads out to rpm to get done and ordered a btr stage 4 cam I have American racing headers and a B&B exhaust with a haltech cai I was hoping to get around 600 whp does anyone have any ideas what I will put down or anyone have anything done similar
Sick427 (04-15-2019)
Are you sure you want a big donkey dick cam that drives like **** just to hit a certain number? -Especially since you thought Undy meant crank hp when he said 550-560...you honestly might want to reconsider to a BTR 3 at least.
Also, periods OP. Periods.
Should be In the 610 to 620 range with stock intake at the wheels. They seem to use a big cam to make big numbers, may end up driving kinda shitty in town. Higher numbers equals less drivability.
BTR 4 should even be a consideration without all supporting mods. I assume you're heads will be ported by saying they're being "done"...but that could just mean a valve job as well I suppose. You have good LT's, but ported heads and a FAST/MSD intake are also needed or you're choking the motor.
Set up
I made 608 at the tire with ported and decked heads,BTR 3 cam, lg LT's and ported stock intake. My setup ran really good and was proven over and over.
