[Z06] C6 Z06 Bronze Valve Guide/Katech Ti/Mo valve inspection after 21000mi + track days
Premium Supporting Vendor
This C6 Z06 came into the shop after 21000mi and an estimate 10 hours of hardcore track day use. It is a great data point to see how the valve guides are doing.
The heads were done by WCCH to Katech's spec with CHE bronze guides, Katech Ti/Mo intake valves and new OEM exhaust valves.
The vehicle is equipped with a Torquer 110 cam, PSI 1511 springs, Katech Ti retainers, OEM lifters, and OEM rocker arms.
The customer has driven it 21,000 miles including a rough estimate of 10 hours on road courses doing HPDEs. He was concerned/curious how the guides were doing after all this and brought the car back to us for cylinder head removal and valve guide measurements. Cylinder heads were torn down to find virtually no valve guide wear. We are simply installing fresh springs/retainers, reassembling and installing back on the car.
We feel we have the best fix available for LS7/LS9 heads. A one and done solution. If you would like this done to your heads, check out our LS7 head bundles here:
https://store.katechengines.com/cyli...dles-c197.aspx
Or installed vehicle packages here:
https://store.katechengines.com/ls7-...kage-p732.aspx
https://store.katechengines.com/ls9-...kage-p751.aspx
OEM rockers/lifters are perfectly fine. I think even more important to note is that it's had a Torquer 110 cam the whole time. Higher lift than stock and the valve guides are still okay.
Alright Jason, I'll bite.. So, what do we think about running the Mo coated Ti intakes with PM or MS90 guides?
Will the coating hold up against that material? Or is this a case of not enough data to make a definitive statement?
What did the surface of the intakes look like in these heads?
Thanks Jason.
Thanks Jason.
A few things to note, the rockers and lifters are original and both now have 38,000 miles (it was noted that they were OEM but not that they were original).
Additionally, because I daily drove this car from May - Oct in Michigan for at least 3 seasons with the refreshed heads, I have a lot of cold starts in temps of 20-30 degree range. I see a lot of people fussing about oil temps in regards to the heads on these cars, but the data from my car and my usage shows no correlation there (granted it is a sample of 1 but consistent with how many on here use their cars).
Lastly, just remembering now that I probably have 40 1/4 mi passes on these heads too now that I think about it (car has gone 10.8 and trapped 133 on a day with decent temps).
Do you mean the surface finish of the intake valve stem?
I don't see the purpose. The point of using PM or MS90 guides is so you can re-use the OEM intake valves rather than purchasing the Ti/Mo valves. If you're going to buy the Ti/Mo intake valves why not just go with the proven bronze. Bronze guides cost is not very significant compared to the cost of the valves.
I don't know. We've never tested with it. I would have engineering take a look at the hardness and surface finish. If that were okay I would like to see a 30 hour durability test on our Spintron. Again, why invest in that when Ti/Mo and bronze are proven?
And there is a point.. We are seeing excessive wear / durability issues on the CrN coating of OEM valves.. So, what if we have a set of heads already re-worked with PM guides, and we swap to Ti Mo to avoid the CrN surface roughness / durability issues? Are the stem diameters materially different between the Ti Mo and OEM intakes?
Yes, intake valve stem finish.
The Ti/Mo intake valve stems looked so good you might be able to pass them off as brand new.
Stem diameter on the Ti/Mo is stock.
As mentioned, here is the CrN failure mode of a tumble-polished stock Ti intake valve. While polishing helps extend guide life, a lack of lubrication is causing the coating to fail. This is where the TiMo valves come into play as the Molly coat gives the valve the required lubricity. Id be curious if cutting little slits into the valve stem seals on the intakes would help them live for those of us that have already "fixed" heads.
Ultimately - this thread is proof that the intake valves with coated molly are the answer.
MickVette (04-19-2019)
Formula8 (04-19-2019)
Yup...
only one valve even registered in thousandths 😳
interesting....imagine if we’d have known this 10-12 years ago, could have saved a ton of LS7’s jihading themselves🤔
and a **** ton of money to the owners....
I hear that. Unfortunately, I am in the process of replacing the replacement heads I bought in 2009, that have 14,300 miles.
Jason, another data point, my guides 10K miles after WCCH head work, your TiMo intake valves, new OEM exhaust valves and K501 cam with 1511 springs and Ti retainers. They were checked while I got the bottom end forged. Quite a bit of time at 4-7K+ RPM and a few track days. Heads were checked and measured at WCCH.
