LS7 HCIE build 3.0 maybe (popped piston)
Last weekend during a 1/2 mile event I popped a piston and cracked a sleeve in cylinder 5.
The plan is to re sleeve this block with Darton sleeves and add forged pistons. Then throw a 200 shot at it. I already talked with RED about doing the sleeves. I was planning on having the rods recoated but now that I got the block apart yesterday I found 4 rods were rubbing 2 of them pretty badly. This LS7 is frustrating. I’m kinda stuck now on how to move forward. I have found 6 ls7 rods locally for $200.
I was also planning on rebuilding the transmission since I have it out.
The other thing that crossed my mind was to throw a used short block in it. Return car back to stock and sell everything that I can’t use on a C6ZR1. Which after yesterday’s findings sounds better.
Ls9 is just more stout
Talk to HPR, have them re-use your block and use it as the basis for a new short-block like I did.
Jayfabs (04-21-2019)
I already did I’m just having a hard time dealing with how much I’m going to be spending on this Z06. I really try to weight my options. I figure new block and nitrous will be 10k plus.
Hey Jay this is Brian, was at the 1/2 mile in November. I have the black Z.
Sorry to hear about your motor.
I too love the c6 ZR1’s. I have driven my buddy’s many times. The one at the event. It has the basic bolt ones and a cam.
makes a little over 800 to the tire. There is no supercharger lag at all. It is scary fast. Doesn’t take much money to get to that power either , and there is room to grow if you want more power,
i heard the 1/2 mile is a standing start now.
Did you get in any runs?
Good luck with whatever you decide .
I did get 5 runs in and broke it on the 5th run. Really sucked.
nice! Yeah I was just at the same 1/2 mile last weekend with Omega. I was going to shift sector this come weekend but not anymore. We’ll see if I fix it it will be wicked with a 200 shot
I do not know. I do know my tuner is highly respected and well known. They other thing I wonder is could my electric water pump have caused me to over heat? My coolant stayed at 205 max during the event
